20 Most Recent LG Flatron L1715S 17" LCD Monitor Questions & Answers
Hi, have you read the manual? More importantly have you installed the display driver on your machine?
LG L1715S Product Support Manuals Warranty More LG
LG Flatron... | Answered on Feb 03, 2018
Go into settings menu and turn of the power saving option.
LG Flatron... | Answered on Jan 02, 2018
It could be a simple cap problem on the control card. But, a 17"? That may not be worth the effort. Unless you have time and curiosity to look for a damaged component on the inner board. Since it does nothing screenwise it is probably something obvious if you open it up.
Good luck with your project. Maybe this will help. https://www.manualslib.com/manual/786974/Lg-Flatron-L1715s.html
LG Flatron... | Answered on Sep 26, 2017
Get a technician to clean them out for you, for safety reasons. it is possible - by the way - to clean flies from the LCD except the fact that you must know how to handle such components as a LCD screen disassembled.
LG Flatron... | Answered on May 20, 2017
if i want turn off the monitor it does not turn off. Connected or not connected is the same while when it was good if there wasn't the signal output the led was orange. Now if there is or there isn't the signal output the blue led blinks
LG Flatron... | Answered on Dec 21, 2014
Obviously a step up transformer is blown. Take it to a repair shop.
LG Flatron... | Answered on Apr 05, 2014
Monitor starts only to powersafe mode
LG Flatron... | Answered on Sep 21, 2013
press the menu button on lcd panel and chaneg the setting of power save . bye
LG Flatron... | Answered on Dec 16, 2012
This is a "feature" they include to prevent accidental changes to the screen setup. You should be able to unlock the OSD by pushing the Menu button and the right arrow button together for about three seconds. The message "controls unlocked" should appear. Let us know if you have any other questions and please don't forget to rate the posting.
LG Flatron... | Answered on Dec 04, 2012
BODY { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } P { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } DIV { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } TD { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } Try pushing the menu button and the right arrow button on the monitor together for about three seconds. The message "controls unlocked" should appear.
Please don't forget to rate this solution.
LG Flatron... | Answered on Nov 27, 2012
Your video settings may actually be out of range of the monitor.
Try starting the computer in safe mode. This will provide basic video without anything fancy. Reset the settings to a lower resolution from the display option in the control panel (or simply right-click on the desktop).
If the display works then, restart the computer and then try different settings from Windows, not the monitor itself.
LG Flatron... | Answered on Dec 04, 2011
Push the MENU button in for 5~10 seconds to turn on/off OSD lock.
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
LG Flatron... | Answered on Nov 23, 2011
I think your cable is damaged.
I've you can pull your VGA cable (BLUE) out of your monitor, you can replace it by a new one.
I've not, you need to get it fixed.
Please rate my solution.
Thank you for using FixYa.
LG Flatron... | Answered on Jun 24, 2011
That is a defect with those monitors...you should get the returned to the store...if you can't then you may have to do some soldering dude...it is a power issue with the monitor itself...you will need to find the replacement capacitor inside..but still the best advice is to return the product
LG Flatron... | Answered on Jun 21, 2011
LG Flatron L1715S 17" LCD Monitor Logo
108 questions posted
Top LG Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Flatron LG
  • Flatron LG
Most Popular Question
l 177wsb powersupply problem
  • Computers & Internet
