20 Most Recent Hotpoint FFA90 Bottom Freezer Refrigerator Questions & Answers
5answers
Hotpoint Mistral Frost Free Fridge freezer - fridge not getting cold
We have just had to call out an engineer to get our 1 1/2 year old Hotpoint Graphite Frost Free Fridge Freezer repaired. The fridge had almost entitely stopped cooling even when on high. I was amazed at how easily the problem was sorted. The engineer removed all the basktes from the freezer to access the screws on the inside backpanel of the freezer. Once this panel was removed it was clear that the so called Frost Free doesn't really mean what it says. The ice need to be melted with a bit of simple care. It is obvious that with a bit of care it is easliy a diy job BUT PLEASE BE CAREFUL AND READ THE NEXT PART BEFORE YOU BEGIN TO REMOVE THE ICE> The ice forms around variouys pipes etc and he usecd a screwdriver to help release the ice quicker than waiting for it to defrost and he also used a simple hairdryer to help speed up the process. He had a ntowel and a basin to take care of the water. Next time I would have no problem doing this myself but I would need to leave it a little while to defrost and NOT USE A SCREWDRIVER as I am sure somehow I would puncture a pipe or the wall of the freezer itself and I am quite used to doing the odd bit of DIY. On a difficulkty scale of 1 to 10 with 10 being difficult I would rate the job as about a 3. Hope this helps anyone who reads this about £70.
1/3/2021 8:35:20 PM • Hotpoint FFA90... • Answered on Jan 03, 2021
Should the fan in a Hotpoint FFA90 be running all the time on the cooling cycle as mine is not.
most fan only go when the doors are closed ?
2/10/2018 1:59:26 AM • Hotpoint FFA90... • Answered on Feb 10, 2018
Freezer defrosting by itself
what's the model number off of the fridge?
2/8/2018 12:44:24 AM • Hotpoint FFA90... • Answered on Feb 08, 2018
On my Hotpoint FFA90 fridge freezer occasional leaks occur at the bottom of the freezer where ice accumulates. The fridge section above is fine. Any suggestions?
There is one in the freezer section as well. It's a small white tube. I've had the same thing happen with mine. I just took everything out of the freezer, and used hot water. It's caused by condensation buildup in the drain tube, which then freezes, obviously because it is a freezer after all. Hot water usually does the trick. Just be sure to clean it up, and dry it off really well so it doesn't re-freeze and cause the same issue.
8/26/2016 6:25:50 PM • Hotpoint FFA90... • Answered on Aug 26, 2016
No power to fan
follow fan wire you will able to find it
5/30/2014 7:18:35 PM • Hotpoint FFA90... • Answered on May 30, 2014
0answers
Hotpoint ffa90p noisy fan
it is ice build up around the fan....defrost it and will be okay...
1/7/2014 7:38:49 AM • Hotpoint FFA90... • Answered on Jan 07, 2014
3answers
Got water leaking from bottom of fridge/freezer on
If you take all the drawers out of the freezer - you will find 8 screws with 'bolt type' heads - 2 top, 4 at sides and 2 to the bottom.
Turn the power off. Undo all these screws and remove the rear panel. You will notice the 'gubbins' of the freezer. At the bottom you should notice there is a shaped plate with some piping running around and then up into the cooling 'radiator'. Towards the middle left of the plate there should be a hole - this is the drain hole. Is it blocked with a 'slug' of ice! Yes is my guess. This needs defrosting as will the rear panel you took out by any guess.
I did ours this morning as the fridge freezer was making a heck of a racket. Took about 30 minutes with the wife's hairdryer - and I'm no expert.
I just enjoy the fact I'd probably saved £50 plus on a callout.
10/3/2013 3:33:13 PM • Hotpoint FFA90... • Answered on Oct 03, 2013
Hotpoint FFA90 Bottom Freezer Refrigerator Logo
106 questions posted
Top Hotpoint Refrigerators Experts
ZJ Limited
ZJ Limited
Jose Ramirez
Sean Wright
Sean Wright
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Refrigerators
Most Popular Question
hotpoint ffa90 fridge freezer occasional
  • Refrigerators
