20 Most Recent LG Studioworks 45 14" CRT Monitor Questions & Answers
yes the diagram is in book of G.T. hardware engineering college jaypur in rajasthan india the books are available in metro citi and authorised suppliers only in that book not only diagram but troubleshooting mathods are also given
LG Studioworks... | Answered on Jul 31, 2018
It's Loose contact Problem in Vertical section
Pl corrected dry points all over the vertical section.
LG Studioworks... | Answered on May 23, 2013
Check components related with pots thats adding command ic to pots.If they are ok then change command ic with new one.Before this you can check horizantal hold transistor that is placed on hitsink of eht.small in size and check two small transistor placed near it on pcb.Hope this solution works .If not then i am here
LG Studioworks... | Answered on Mar 13, 2011
When any dust goes inside your monitor .......you will get these things.......... remove it , it will work fine
LG Studioworks... | Answered on Feb 28, 2010
check crt bord 70v. or-volt
LG Studioworks... | Answered on Aug 26, 2009
this is because some dust might have gone inside your monitor so only you are getting this problem..... If you just remove it. It will work fine..
LG Studioworks... | Answered on Feb 12, 2009
1. LOT problem.
2. Horizontal transistor bad.
3. Dry points in neck board, horizontal section.
4. transformer output capacitors problem.
5. IRF 630 ( lot supply fet )
LG Studioworks... | Answered on Feb 05, 2009
LG Studioworks 45 14" CRT Monitor Logo
Popular Tags
41 questions posted
Top LG Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Studioworks LG
  • Studioworks LG
Most Popular Question
crt monitor becomes yellowish
  • Computers & Internet
