20 Most Recent
LG Flatron 776FM 17" CRT Monitor Questions & Answers
I have HP w2338h sound won't work
download sound drivers from the internet for your Model Hp ,there are no sound drivers or sound drivers got faulty due to virus or update.
This is the second time it's happend and it's the
Well LG stands for Lotta Garbage!
Try checking the monitor to PC cable, if it's not fully on it will cuse color spread like you describe. One of the pins may not be inserted into the cable properly.
Please rate my help++++Thanks for using FIXYA
LG Flatron 776FM mic is not working
it is the one that is blue in color and has an L on it for low
pressure. The vapor line is also called the suction line. If your
confused, then choose the larger of the two lines near the accumulator.
Need driver compatible to vista or windows7 for the monitor
Hi friend,
You are right in time I will give you the addresses of two websites from where you can download drivers or in that case any software.
The sites are www.brothersoft.com and www.bitcomet.com. And the best thing in both these sites is they dont charge you anything.
Thank you for giving me a chance to help you out:):):)
And please vote/rate me so that I can improve myself and be of more help to you:):):)
Prasanth83:):)
Monitor displaying 'check signal cable'
Make sure the refresh rate is set at 60 hertz before using the new monitor also check the display settings to see if they are set to use the external display also. Yours may automaticaly do this and your partners may not. If this does not help please let me know the type of notebook and monitor. Good Luck!
Shape of LG Monitor
What are actual value for all the shape properties?
it is already in owenr's manual.
