20 Most Recent Sony Handycam DCR-HC21 Mini DV Digital Camcorder Questions & Answers
2answers
My sony dcr hc21 touch
If the touch screen of the Camcorder is not working, please follow the troubleshooting steps.
  • Please make sure that you're using fully charged batteries.
  • Turn off the Camcorder and turn ON again and check the operation.
  • Try resetting the Camcorder by pressing the reset button behind the LCD panel.
  • If the issue persists again, please perform LCD screen Calibration and check if that helps. Please follow the steps below to perform the LCD Calibration.
  • Perform a power resetting of the Camcorder. To perform power resetting, please remove the battery pack, turn the Power switch to Play/EDIT/ON for more than 15 seconds, turn the Power switch to OFF position and then reinsert the battery pack.
  • If the issue persists even after performing all the above-mentioned steps, service is required.
I hope this information will help you to resolve the touch screen issue of the Camcorder. If you require any clarification or any help, please let me know. Thanks for understanding.
11/10/2017 1:58:31 AM • Sony Handycam... • Answered on Nov 10, 2017
Sony handycam dcr-hc53
I think you are using Windows Vista and facing problem to connect Sony DCR-HC53
Download Update for Picture Motion Browser software at Sony Support.
You need iLINK cable to transfer movie data in to computer. iLINK cable is shown in below picture.
You can have more info HERE about iLINK connectivity if you are running Windows XP in your laptop.
5/18/2017 6:29:32 AM • Sony Handycam... • Answered on May 18, 2017
LCD screen stopped working
sounds like the LCD screen viewfinder may have been twisted or accidentally catched or got hooked or snagged on on something at one stage and pulled something, if the screen went yellow it means the three wires going to it are possibly broken or the small white clip was slowly coming undone inside the Viewfinder for the red and green to no longer work to complete the image also indicates why the buttons on the viewfinder are not responding, try twisting the viewfinder very lightly whilst on, but most likely the small white clip holding the wires has come off at the elbow inside the camera
4/26/2017 4:20:01 AM • Sony Handycam... • Answered on Apr 26, 2017
I cannot find the drivers for windows 10
hi, guys who need cheap windows can click here www.aakeys.com 100% working keys here, really nice
6/3/2016 2:39:44 PM • Sony Handycam... • Answered on Jun 03, 2016
Cannot see anything thru view finder or touch screen but very faint image only with camera on or off and flip screen open or shut
Hi, pls check the out put video signal by connecting with an external monitor, if the picture is OK, then there could be fault in the LCD connecting point, must check the flexible connector.
3/17/2016 6:43:35 PM • Sony Handycam... • Answered on Mar 17, 2016
Were can i get a LCD circuit board for Sony HDR-sr11
It's rare that this part has to be replaced. If you have trouble viewing the screen, or if the menu buttons do not work, more than likely, the flexible cable that goes from inside the body to the flip out LCD needs to be replaced. If you require Professional service, we can help! Contact Us at AVRepair com
7/16/2014 5:56:25 PM • Sony Handycam... • Answered on Jul 16, 2014
Error code c:31:23
Sony is pretty secretive about the :23 code. It can't be found anywhere. However, to service the C:31 code, Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
5/17/2014 10:44:34 AM • Sony Handycam... • Answered on May 17, 2014
2answers
SONY DCR HC21 touchscreen buttons/functions suddenly not working
yes, seems its flexible wire that is bad.
11/15/2013 9:49:05 PM • Sony Handycam... • Answered on Nov 15, 2013
Usb driver Sony Handycam DCR-HC21 Mini DV Digital Camcorder
You may download the driver from here.
11/3/2012 1:46:55 PM • Sony Handycam... • Answered on Nov 03, 2012
Sony Handycam DCR-HC21 Mini DV Digital Camcorder Logo
299 questions posted
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Handycam Sony
  • Handycam Sony
Most Popular Question
please down load manual
  • Video Cameras
