My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Sony Handycam DCR-HC20 Mini DV... • Uploaded on Oct 23, 2013
Sony Handycam Video Cameras • Uploaded on Sep 16, 2013
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and will require disassembling the camera and LCD assembly to repair. This can be done fairly inexpensively but it's not really a user serviceable problem and should be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Error code 61:00 indicates a problem in the focus mechanism. The most likely cause for this is a lens out of place or impaired in some way. This will require disassembling camera to remove the lens block and then disassembling the lens block to repair. This can be done fairly inexpensively. However, it's not really a user serviceable problem and will need to be repaired by a qualified service technician.
This is usually caused by a defective CCD image sensor and will require disassembling the camera to repair. The lens assembly will need to be removed, the old CCD de-soldered from the circuit board and a new one installed in its place. This can usually be done fairly inexpensively. However, it's not really a user serviceable problem and will need to be repaired qualified service technician.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
The most likely cause for this is a zoom or focus lens out of place or impaired in some way. This will require disassembling camera to remove the lens block and then disassembling the lens block to repair. This can be done fairly inexpensively. However, it's not really a user serviceable problem and will need to be repaired by a qualified service technician.
This error code indicates a problem in the tape transport system and can be caused by several things including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
Sounds like a sensor problem. I recently called Sony with a similar problem for my own mini DV cam. They will give you a repair cost estimate and tell you how to send it to the company for repairs. They are also refurbishing my cam, besides replacing lens and sensors. It's worth the cost to avoid having to purchase a new camera. I have 7 or 8 Sony DV cams for my media business, and this is the only time sending one in for repairs.
The number as listed on the Sony website: Priority Service Line (for U.S. only): 239-768-7547. Once you wade through the maze of recorded menu options, and get to Camcorder Repair service department, they will help you very efficiently.
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
126 questions posted
310 Questions
243 Questions
242 Questions
159 Questions
150 Questions
