20 Most Recent Sony Handycam DCR-TRV33 Mini DV Digital Camcorder Questions & Answers
CCD Failure !!
u can try Sony for free CCD replacement as it is a known issue in thousands of cameras see the link here, it starts with these horiz lines and verrtical noise type thing and suddenly it also turns black or blank screen after sometime , u are covered in this advisory list 100% i am sure see the links below and pls rate me FIXYA for help
see this comment on cnet forum
DCR-TRV33 Free Repair by koertd - 3/9/08 3:45 PM In reply to: Sony DCR-TVR22 – tape stuck by willibo Thanks to all. Ready to trash my DCR-TVR33, but found the cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif800-222-1669cb_transparent_r.gif number. While holding, I found online support at: http://esupport.sony.com/perl/news-item.pl?news_id=161&mdl=DCRTRV33
(I guess several trips to Hawaii and Fuji didn't help the humidity/temperature issues!)
The friendly Sony representative had me reset the camera and then offered to have the problem fixed for free, including shipping.
see this forum here
http://forums.cnet.com/5208-7594_102-0.html?threadID=51594&start=285
http://www.imaging-resource.com/NEWS/1164379168.html
http://www.imaging-resource.com/badccds.html
What do u think Mr. Welcomejee have i diagnosed it correctly or not ?
Sony Handycam... | Answered on Nov 21, 2019
Take it for a service - 'No user serviceable parts within' applies here.
Sony Handycam... | Answered on Jun 29, 2017
Use the IEEE1394 Firewire interface on your PC if you have one. If your PC does not have a IEEE1394 port then you may be able to add one via an internal add-on card or a PCMCIA card if it is a laptop. With Windows 7, you can use Windows Moviemaker to capture the video. Don't bother with USB capture as this will be low quality and too slow. Moviemaker is not great for editing so you should investigate alternatives.
Captured video will take about 4GB of hard disk space for 20 minutes of video. If you are using a FAT32 file system then this is the maximum file size limit. You should therefore use NTFS to capture large video files.
Sony Handycam... | Answered on May 25, 2016
That's easy, much data recovery software can solve your problem.I recommend you have a try of Wondershare Data Recovery,This program is equipped with four critical modules:"delete recovery", "format recovery", "partition recovery" and "raw recovery". It can help with your case.
Sony Handycam... | Answered on Mar 31, 2016
Sony video camera serial No 1336920 N50 software needed
Sony Handycam... | Answered on Oct 11, 2013
Can you please explain batter
Sony Handycam... | Answered on Nov 22, 2011
The 32:10 error code indicates a problem in the cameras tape transport system. This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly, a defective clutch in the take-up spool or a faulty rotary mode switch. This will require disassembling the camera to repair and can be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
m.
Sony Handycam... | Answered on Sep 15, 2011
This is usually caused by a defective CCD image sensor and will require disassembling the camera to repair. The lens assembly will need to be removed, the old CCD de-soldered from the circuit board and a new one installed in its place. This can usually be done fairly inexpensively. However, it's not really a user serviceable problem and will need to be repaired qualified service technician.
Sony Handycam... | Answered on Sep 07, 2011
This is usually caused by an oxidized, misaligned or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair cost low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
Sony Handycam... | Answered on Aug 11, 2011
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
Sony Handycam... | Answered on Jun 22, 2011
The USB streaming driver for the Camcorder is not available for Windows 7 OS from Sony at this point. Hence it is not possible to transfer videos using USB interface. You may use i.LINK or A/V interface to transfer videos from the Camcorder to the Computer which is running on Windows 7 Operating System.
Please follow the steps to transfer video to a computer using an i.LINK connection (IEEE 1394).
IMPORTANT: Video capture software and a compatible video capture card must be installed on the computer. Depending on the computer manufacturer, various video capture cards and software (Adobe Premiere, Roxio Video Wave, Microsoft Windows Movie Maker, etc.) may be available or already installed on your computer. If necessary, contact the manufacturer of your computer for further information.
NOTE: Many Sony VAIO computers are bundled with Sony DVgate Motion or DVgate Plus software for video capturing. Some VAIO computers also include Click To DVD software that will allow video capture to the computer hard drive or directly to a DVD.
  1. Connect an i.LINK cable (also known as IEEE 1394) to the i.LINK port on the digital camcorder.
i.LINK Cable.
i.LINK port.
  1. Connect the other end of the i.LINK cable to the computer.
NOTE: The computer i.LINK ports and capture cards may have either 4-pin or 6-pin connections. Sony digital camcorders use i.LINK ports with 4 pins. If your computer only has a 6-pin i.LINK port, then it will be necessary to use a 4-pin to 6-pin i.LINK cable.
  1. Turn on the digital camcorder by moving the POWER switch to the VTR position.
  2. Cue the camcorder tape to the beginning of the video footage.
  3. Turn on the computer.
  4. Start the video capture software on the computer.
  5. Begin playing the recorded video in the camcorder.
  6. Begin importing the video with the capture software.
It should now be possible to copy the video using the video capture software if the computer hardware and software are configured correctly.
Thanks for understanding. Please let me know if you require any further assistance.
Sony Handycam... | Answered on Jun 20, 2011
Sony Handycam DCR-TRV33 Mini DV Digital Camcorder Logo
152 questions posted
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Handycam Sony
  • Handycam Sony
Most Popular Question
upload minidv tapes pc running windows
  • Video Cameras
