20 Most Recent
Sony Handycam DCR-PC105 Mini DV Digital Camcorder Questions & Answers
DCR PC 105 was dropped. Now auto focus only works
The most likely cause for this is a zoom or focus lens out of place and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Sony PC-105 - camera won't charge, hence tape will not eject. Is
I just had the same issue except I left my camera out in the rain. My camera is a DCRF-HC32 Sony Handicam. There is a reset button on the side of the camera where the eject door is. Take a paper clip and hold the reset button in for 5-10 secs. The camera will beep, power on, open the door and it ejected.
Zoom is stuck
Just check the DC power supply flowing to the Lens block control.
Some times the SMD fuse blows off and power may not reach the lens block motor.
Converting video content to a CD/DVD through the computer
You need a computer with 1394 firewire card and a 4 pin to 6 pin firewire cable. The 4 pin end goes on i-Link connector on camera end the other end of the cable on the computer card. If you have a notebook, will you need 4pin to 4pin firewire cable.
I've lost the cd, where can i download a copy?
Call or email the sony support team. You can have them send you a new cd. It may cost a couple of bucks thought. If you need it for free you can try to find it on a peer to peer network but the chances of finding are slim and it will take some work.
Driver for sony camera
I found the link to get the drive on the sony website in the United kingdom. http://support.sony-europe.com/dime/camcorders/dv/dv.aspx?l=en&m=DCR-HC17E
Hope this is helpful.
It will not turn on.
In havin the same problem its insane! It was working from xmas up to like half way in January. Any Solutions?
Cannot record
it is a reel sensor problem...try to adjust the contact of the sensor at the main board sometimes it is a poor connection or poor solder...
Power Zoom Lever Doesn't Work
please try to use the memory stick. If there is a message MS error, please look at this picture.
Best regards,
Arpi
If you need more info please advice.
Sony DCR-DVD200 camcorder not turning on after trying to fix it.
The best thing you can do now is to take it to a specialist and get them to do the repairs. Camcorders have a lot of electronics in them and can be easily damaged if your a not an experienced repairer. You might also have to consider that this camcorder might not be repairable.
