20 Most Recent
LG L1930S (Silver) 19" LCD Monitor Questions & Answers
What normally burns out the LG Hi-Fi Amplifier?
Full 'make model (what it is)' in all questions please, first 3 words.
Capacitors can split or bulge, resistors can burn,, the transformer can fail internally..
Take it for repair unless you have the thousands of dollars of test equipment and have do the 2 year electronic course.
What does 9 red flashes mean on LG multi V LMU540HV
A communication error has occurred between the outdoor and indoor units. Faulty wiring or a malfunctioning control unit may be responsible. Contact LG customer service for assistance. Their number is 1 800 243 0000.
How to sync TCL ROKU TV to LG sound bar
You will need to connect a single HDMI cable from your sound bar to the HDMI ARC or the HDMI eARC port on the Roku T.Make sure that both of the devices are both turned on.When your TV detects the sound bar,it will then automatically initiate the setting up process. Lastly follow the easy on screen instructions to finish setting up the connection.
LG 55UM7300PUA not powering on
If your LG 55UM7300PUA is not powering on, there are a few things you can try to troubleshoot the issue. 1. Check the power cord and make sure it is securely connected to the TV and to the wall outlet. 2. Check the wall outlet to make sure it is working properly. Try plugging in a different device to the outlet to make sure it is providing power. 3. Check the power button
Where is the off button on my LG laptop
the typical power button looks like an open circle with a line through the top where the opening of the circle. Usually it's located at the top -right portion of your keyboard.
If not there, then please check the sides of your keyboard as well.
Thank you.
