20 Most Recent
Sony Handycam DCR-TRV320 Digital Camcorder Questions & Answers
DCR TRV320
That is the "LOAD" error code.
However, to service the C:31 code, Sony recommends you do the following:
- Turn off the camcorder.
- Remove the battery or disconnect the AC power adapter for 60 seconds.
- Insert the battery or reconnect the AC adapter.
- Turn on the camcorder.
- If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
I bought a new Memory
Check the following:
Memory Stick is inserted in correct position and orientation in camcorder. Try re-inserting several times.
Write-protect tab is switched to allow writing to memory stick (on back of memory stick)
Memory Stick is formatted in FAT file system (this should already be done except if memory stick has been formatted in a computer in a different format)
Memory Stick is not over the maximum capacity memory stick of the camcorder.
Memory Stick is not full.
Memory Stick is clean and dry.
The dcr-trv320 is a 2000 yr. model and came with a 4mb capacity stick and can probably only use up to a 128mb capacity stick or possibly 256mb. Most memory sticks you can buy today are 1GB, 4GB, 8GB etc. memory stick pro duo. and are probably incompatible. E-Bay has some of the old memory sticks like the 128mb for sale.
There is a slight possibility that static electricity discharge zapped the stick. Try another memory stick or try the stick in another device.
I have a C:31:23 code
Tape mechanism problems can be quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Tape door won't close
Tape mechanism problems are quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
The playback is staticky (spelling???)or
Kinda mosaic-like noise?
Possible cause
-dirty playback head
-dirty or worn-out tape
-running tape recorded from different camcorder.Tape will play back best in the same cam that recorded it.
My hi8 camcorder is not playing back or rewinding
These are great cameras in fact I would still say they are the best ever made as yet, and yes it can be repaired, call Sony (Weekdays 9-4pm) on 01256 828828, listen to options then select Camera support, all the best.
David
I have an E61:10 error on my camcorder TRV 320.
As weird as it might sound, it seems that several error codes on Sony's camcorders can be solved by simply shutting off the camera, removing the battery - and giving it 2 good smacks! Yes... I know it sounds stupid, but the more I search about it (this is the second time) I see more and more people supporting this "unofficial" solution!
Read this
forum thread (as a little proof).
Good luck,
Pelu.
How do I change from LP to SP ?
for the dcrtrv320 here's how you do it.ensure you have the power switch set to camera/vtr. press the menu button. will give you little icons on the screen (you should see manual set or vtr set). scroll down to the icon the looks like a tape (tape set). use the sel/push exec dial (it's the dial near the menu button,bottom of the viewfinder and left side of the batt) you scroll it up/down and push it in to confirm your selection.in tape set you have rec mode (press sel/push exec dial in)scroll to sp and press sel/push exec dial again to confirm setting. press menu to exit menu settings. hope this helps.thanks :)
Got camera wet
If your device gets covered in water, act fast and rationally, and you may be able to save your device.
1. DO NOT TRY TO TURN IT ON
2. Pull out the battery.
3. Please your device and battery into a bowl of uncooked rice to absorb any moisture.
4. Please it in a warm, dry place where it can receive direct sunlight.
5. Be patient. It is recommended that you leave it in there for at least 48 hours.
6. After 48 hours, put the battery back in and power on.
How do you get images onto the computer
You should be able to use a USB cable to connect the device to a computer, or take the memory stick from the device and use an adapter with your computer to access it like a flash drive or external hard drive. If you are using an SDHC memory card, you must buy a SDHC compatible adapter and meet the criteria for the adapter.
Manual eject option for trv320?
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
- Remove the battery from the camera.
- Remove the AC power supply from the camera.
- Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
- Slide the power switch back to the OFF position.
- Connect the AC power supply to the camera.
- Attempt to open the cassette compartment.
VTR mode controls are not working properly
Hi, You need to replace the switch block control whic has all you play and zoom functions. Or, you could use your remote control to do these functions instead.
mr cicmo
Transfer videos from handycam to PC
i will give you a step by step on your camcorder.
- connect your camcorder using your USB cable to your computer and be sure it is ON
- Install the cd driver camed with your camcorder. if you didnt prompt on looking for a driver then go to the add hardware on the control panel and follow the procedure there.
- after the installation you should see the icon on the my computer labeled scanners and cameras and indicating the model of your camcorder.
- Install Ulead Power Producer or any editing movie that you have like Windows movie maker, nero movier maker etc.. i prefer to use Ulead because its so easy to use
- after uploading and editing your videos using ULEAD save it on any various types of videos that you like. you should see it after you want to save it.
- burn your videos on NERO software
Hope you understand my procedures. Good Luck!
CHARCOIS
