20 Most Recent
JVC Everio GZ-MC100 Memory Card Camcorder Questions & Answers
After formatting the CF-card the camera still
There's A Fault In The Format Way , Try This
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
How to transfer to computer?
You must have a connection cable to your computer (USB ).
just plug it and your computer recognize it automatically as external Hard disk..than copy the files and paste it into PC..good luck.
I have a brand new JVC GZ-MS100 and a brand new card
The 32GB SDHC card may be a "class 4" card, not a "Class 6".
Look at the card and find the circle with a number in it.
Class 6 is the highest speed available. Class 4 is much slower and can't keep up with video.
Not all 32GB sdhc cards work with all camcorders.
Try formatting the card twice in the JVC.
What kind of card is best
The MPEG2 recording can be used in various quality levels, with 8.5 to 5.5 Mbps constant bit rate and 4.2 and 1.5 MBit / s with a variable bit rate recording.
The read / write speed is 20480 kb/s (SanDisk data).
It's enough!
Calculate the recording time:
click
Formatting?
try to format the cf card on a pc (use a card reader)
Hope it helps
marco
