20 Most Recent JVC GR-D270 Mini DV Digital Camcorder Questions & Answers
I have The JVC GR- D270 its about 10yrs old and it skips every second while playing an the Safe guard at times will interfere the playing . Now what?
JVC GR-D270 Mini... | Answered on Mar 19, 2016
hi,
there is several reasons for not work the record function, first of all make sure that the cassette is good and the safety tab is in record position, then check the playback of the cam with a recorded cassette, if this tests passed, check the rec button for loose or it is sticky, if so please use contact cleaner in the switch.
still the problem persists there should be problem in the circuit board. open total camera put it in record mode then test the wave shapes in the record paths up to the video head
JVC GR-D270 Mini... | Answered on Feb 25, 2016
I was unable to fix it but left it plugged in and on and after a long period of time it would work. Maybe the heat from being on. Try storing it in a bag with desiccant packs.
JVC GR-D270 Mini... | Answered on Mar 24, 2015
Hi guys,
I have a JVC gr-d270. the CD came along with it is useless. my computer cannot detect the video cam hrough USB. I have to transfer my videos to my computer. Can anybody help me with the driver atleast. Im using windowsXP sp 2.
Thanks
JVC GR-D270 Mini... | Answered on Jan 23, 2015
Unit stuck in safeguard mode
JVC GR-D270 Mini... | Answered on Aug 27, 2013
You may download a copy of the manual from here. It appears the camcorder was introduced around January of 2005.
JVC GR-D270 Mini... | Answered on Oct 24, 2012
The GR-D270U uses SD cards. They should be available at just about any department, electronics, or office-supply store.
Make sure you get an SD card, not an SDHC card. While SDHC cards will fit into the slot, they are electronically incompatible and will not work.
JVC GR-D270 Mini... | Answered on Sep 19, 2012
it sounds like your head needs aligned
JVC GR-D270 Mini... | Answered on Jul 20, 2012
not possible only support memory stick
JVC GR-D270 Mini... | Answered on Jun 25, 2012
Your loading motor is no longer working or your mechanism is out of alignment.
JVC GR-D270 Mini... | Answered on Jan 24, 2012
This is usually caused by a defective CCD image sensor. This will require disassembling the camera and removing the lens assembly to repair and can be done fairly inexpensively. However, it's not really a user serviceable problem and should be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
JVC GR-D270 Mini... | Answered on Oct 25, 2011
http://xpdrivers.com/jvc/_2_135637.cfm?gclid=COGa4tjm0aoCFQ6AgwodzX7Qzw
Follow the link above!
JVC GR-D270 Mini... | Answered on Aug 15, 2011
JVC GR-D270 Mini DV Digital Camcorder Logo
116 questions posted
Top JVC Video Cameras Experts
Ekse
Larry Stiles
Larry Stiles
Al Rush
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
View Most Popular
GR JVC
  • GR JVC
Most Popular Question
record button not workig
  • Video Cameras
