20 Most Recent
JVC GR-SXM260E Camcorder Questions & Answers
Camcorder says lens cap on when not on
This is a known fault, JVC recalled a lot of these camcorders in 2007. They were manufactured with defective components.
Contact JVC customer Services and demand a replacement.
Camcorder stuck in E02 Safemode
hey have the same problem with my camcorder too far the past 3yrs send it to jvc they said no problem found but as soon i got it back it work for one day them went back to safe mode.they said they could rplace the head mechanicalism for $350 which is roughly what paid for the camcorder.if gotyours fix let me now
CAN NOT SEE PICTURE
the rotating video head circuit is faulty. problem may be deeply rooted on a circuit board or as simple as head not spinning. can you hear the head spinning?
JVC GRSXM260U
you need to clean the heads
use or buy cleaning tape
Video to Computer
As far as i can tell, your Nvidia is only capable of outputting video, if you wish to input video from your camcorder you will need a video capture card. the cable will then depend on the configuration of the card, but may well be a standard s-video cable.
Try a quick visit to a computer store, and see what video capture devices they have to offer, if you need more advice on these then please ask.
An alternative solution would be to hook your camera to a stand-alone dvd recorder using the s-video connection. You should then be able to watch and edit this footage in your pc - you will probably need some software to do this(ask if you need help), but you should be able to at least view your footage in windows media player or similar.
The cheapest option may turn out to be replacing your camera with a digital one that can be directly linked to your pc through a USB connection or similar. all the processing of the image is done by the camera and the software that comes with it, so no need for a graphics capture card.
Follow this link if you wish to obtain more information about your Nvidia card.
http://www.nvidia.com/page/home.html
Hope this helps :)
Why won't my digital camera charge via USB anymore?
Take camera and its battery to a camera outlet, ask them to check the built-in rechargeable battery.
Most outlets will help you with this, as its likely that if the battery has failed, you'll buy a replacement from the same dealer.
