20 Most Recent JVC GR-D275 Mini DV Digital Camcorder Questions & Answers
Turn the power switch on your camcorder to "Off." Connect the USB cable that came with the camcorder to the USB port on the camcorder. If you are using the DV cable, connect one end of the cable to the computer first. Put the other end of the USB cable into the USB port on your computer. If you are using the DV cable, connect it to the camcorder. Power on your camcorder. Wait while your computer recognizes the attached JVC GR-D270U camcorder. Typically you will get a pop-up on your screen asking how you want to proceed once the camcorder has been recognized. Open your video editing software, such as Adobe Premiere, Roxie, iMovie or Windows Movie Maker. Import, or capture, the video from the camcorder to your computer using the video editing software. For example, in iMovie you click on "File," then "Import from Camera" to download the movie from your camcorder to the computer.
JVC GR-D275 Mini... | Answered on Jan 13, 2018
hi dear technical support manger . I want to install software . my digital camera model GR-D750
JVC GR-D275 Mini... | Answered on Apr 19, 2015
Hi Parker,
First of all you need to install GR-D275 driver on your PC. This driver should in one package with your camcoder when bought.
If the driver has been installed on your PC then your camcoder being connected to PC, click right bottom on yourpc screen tagged with ' Shows hidden Icons while you pointing the 'up' arrow. Then choose USB icon and search for your camera .
Regards
JVC GR-D275 Mini... | Answered on Oct 22, 2011
Sorry this needs professional repair
JVC GR-D275 Mini... | Answered on Jul 04, 2011
do you have the manual
JVC GR-D275 Mini... | Answered on Feb 23, 2011
Remove the memory card and you will find a switch on the left side of the card. It must be locked, so slide or push the lock on other side to open it and then Format It.
Regards
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
JVC GR-D275 Mini... | Answered on Jan 03, 2011
Unfortunately, even if there were a USB adapter, the USB port would not be able to keep-up with the data transfer speeds of the DV-Out over firewire from the camcorder.
Sorry for the bad news. I wish that I could have provided better news.
Thanks for using FixYa and Happy New Year.
JVC GR-D275 Mini... | Answered on Dec 31, 2010
The compatible memory cards for your camcoder are Secure Digital (SD) and multimedia (MMC) cards. If you still get same massage remove then re install your card. Please be carefully to insert the card. Orientation of card should be observed before push in the card.
JVC GR-D275 Mini... | Answered on Dec 04, 2010
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
JVC GR-D275 Mini... | Answered on Sep 25, 2010
Mechanism of your camcorder has to be serviced.
JVC GR-D275 Mini... | Answered on Nov 19, 2009
Only you can download from the memory stick video caseete is not support with this model.
JVC GR-D275 Mini... | Answered on Sep 28, 2009
try to ccd base and iris unit on optical block assy
JVC GR-D275 Mini... | Answered on Sep 12, 2009
Probably you had not used your camera for a long time, keep it running for sometime, this may solve the problem.
JVC GR-D275 Mini... | Answered on Sep 11, 2009
driver name for a camera ddv-660
http://hotfile.com/dl/11754833/8b18208/EUROCYBER_DDV-777X-Driver.rar.html
JVC GR-D275 Mini... | Answered on Sep 07, 2009
JVC GR-D275 Mini DV Digital Camcorder Logo
42 questions posted
Top JVC Video Cameras Experts
Ekse
Larry Stiles
Larry Stiles
Al Rush
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
View Most Popular
GR JVC
  • GR JVC
Most Popular Question
when push eject button motor not
  • Video Cameras
