20 Most Recent JVC Cybercam GR-D70 Mini DV Digital Camcorder Questions & Answers
WHERE CAN I ARRANGE REPAIR OF JVC VIDEO C
Check out JVC web site for guidance. but with the cost of these items getting to be so relatively inexpensive, it may not be cost effective to have it repaired.
1/8/2016 8:32:21 PM • JVC Cybercam... • Answered on Jan 08, 2016
Cannot switch on
check whether the switches are jamed or not? did u try with the charger alone? there is no way u can get tape with out powering it up.
ny way u hav i-link cable of that one?|
5/1/2015 6:04:24 AM • JVC Cybercam... • Answered on May 01, 2015
0answers
2answers
Mini-DV TRAY OPEN..Camera shows E-04 Problem Code
FIrst, tap the side of the camera with a good thump, and it will remedy the problem immediately.
Then, to prevent it happening again, do the following:
1. Chuck out all those cheap crappy tapes you purchased to save a buck. Get JVC or Panasonic.
2. Chuck out all those cheap generic batteries you purchased to save a buck. Get JVC
3. DO NOT STORE OR TRANSPORT THE CAMERA WITH THE FILM IN, OR THE BATTERY ATTACHED!
4. ONLY AFFIX BATTERY AND FILM IMMEDIATELY PRIOR TO USE. Keep both in their proper containers.
if that doesnt work
i'll tell you the secret. the moisture sensor is a little black square on the side of the drive motor. if you look directly where the tape goes in, the drive motor is in the far back left. it's partially hidden behind a silver pin hanging down from the black plastic cover that goes over the video head. take a long q-tip and dip it in glass cleaner(windex etc) and gently wipe it off. you should see a small amount of black guck on the q-tip.
then remove power for about one minute and allow to dry. it's better to use air to dry it out.
12/18/2013 10:24:30 PM • JVC Cybercam... • Answered on Dec 18, 2013
2answers
2answers
JVC Camcorder
JVC does not show this model to be a valid model number in the database. The model series begins with the GR-D32U which I have a manual for. If you would like, I can convert it to a PDF for you and email it to you. Joe Weibel Custom Electronics (customelectronics.org)
10/9/2012 5:11:40 PM • JVC Cybercam... • Answered on Oct 09, 2012
Failure of the CCD image
Te image sensor is replaceable. The cost for the part runs about $130. The labor to install it will vary from shop to shop but you are probably looking at around $200 to repair your camera.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
9/17/2011 6:16:43 PM • JVC Cybercam... • Answered on Sep 17, 2011
Trying to record and its saying open len cap
Try taking the lens cap off.
9/7/2011 12:42:28 PM • JVC Cybercam... • Answered on Sep 07, 2011
My jvc digital video camera
Only if the camcorder is within the WARRANTY limit and has not been tampered will it be possible to get the free replacement.
However you can log on to the JVC SUPPORT site and post your problem to get a response.
If you have an authoirised service center aroung your place it will be best to get in touch for an estimation.
http://support.jvc.com/
7/30/2011 3:52:57 AM • JVC Cybercam... • Answered on Jul 30, 2011
2answers
Where I can buy a CCD part for my JVC GR-D70U
Same problem like most cameras. CCD is dead. Need to replace with new CCD. Now the problem is where I can buy this part.
7/30/2011 3:51:38 AM • JVC Cybercam... • Answered on Jul 30, 2011
I'm trying to get video
You are not able to convert the DV to digital data because there is conflict of the format and the type of file. So it is required that a software must be downloaded to the PC so that the DV files are copied and converted.
Please check the following link and download the program to be used to convert the DV files.
Click on:
http://www.xilisoft.com/dv-to-dvd-converter.html
You can convert the DV to DVD by using the converter.
6/22/2011 10:26:16 AM • JVC Cybercam... • Answered on Jun 22, 2011
Condensation operation paused how do
If the camera is working correctly it's to protect the camera and tape.
The camera has detected condensation inside it's body due to a large change in temperature. eg. when you take the camera form a heated room to an external environment that is very cold.
You simply wait until the camera acclimatizes.
Al
2/13/2011 2:49:38 AM • JVC Cybercam... • Answered on Feb 13, 2011
0answers
JVC Cybercam GR-D70 Mini DV Digital Camcorder Logo
103 questions posted
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
View Most Popular
GR JVC
  • GR JVC
Most Popular Question
user manual gr d20ek
  • Video Cameras
