20 Most Recent
JVC Digital Video Camera Questions & Answers
E04 Error
Use only JVC tapes!!! Then bang on the speaker and it will work. Sounds weird, but it works.
My camcorder is a jve
I need JVC camcorder model number to diagnose the problem, model number would be written on bottom side of camcorder.
Thanks.
Hi the screen shows the message
This is usually caused by a failed component in the moisture detection circuitry within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Jvc 700x digital zoom video
Hi Ginette
The camcorder has a built in Dew sensor that monitors the condensation in the area of the camcorder while it is in use. Normally after leaving the area where the condensation is and the camera sitting for a while it should reset itself, if it doesn't then the dew sensor needs to be replaced. On the model that is shown in the picture it is on the motor bracket assembly. I could be more specific if i had an exact model number.
I hope this helps.
Condensation, operation paused
This is usually caused by a failed component in the moisture sensing circuitry within the camera and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
Condensation operation paused
Condensation errors are quite common and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be diagnosed by a qualified service technician.
I have a error saying please wait condensation
It probably means that a moisture sensor has tripped inside the recording mechanism.
Did you take the camera from a cold (i.e air-conditioned) place into a warm place?
Generally waiting 'til the camera has warmed up and whatever moisture inside has gone away will let you use the camera again.
Unit in sageguard mode
"safeguard mode" indicates a hard failure, normally associated with the mechanism. Try ejecting the tape if one is in the unit. Do not force the mechanism open as it will cost more have the cam repaired. If tape is defective and can be removed, try using a cleaning tape first, then a known good tape.
Remove the cassette mechanisum and clean the sensor on the loading motor or replace with new one
