20 Most Recent LaCie Electron 19" CRT Monitor Questions & Answers
6answers
Image collapses to a bright white horizontal iline
I resolve this problem this way.
In first about source of the problem - the solder in some contact destroy during some time (2-2.5 year) through temperature conditions. In result lost contact and award as a bright white line (some minutes and good bye, tube!).
I second - how I decide problem.
Please, see this picture - http://img165.imageshack.us/img165/3280/crw7783sc3.jpg
You see problem areas inside red circle.
I don't open the monitor (this is very difficult), but it age about 4 year and it out of guarantee.
I hack the bottom of the monitor -
http://forum.ixbt.com/post.cgi?id=attach:28:10071:1360:1
and solder this contacts again. (This photo show back side of monitor)
After I try restore hole's edges...
Now my monitor shows without problems!
2/4/2013 11:56:10 PM • LaCie Electron... • Answered on Feb 04, 2013
OSD locked out
hello you have Resolved ?
thanks andrea
12/29/2010 4:56:50 AM • LaCie Electron... • Answered on Dec 29, 2010
0answers
6answers
Screen goes black with bright white horizontal line
This problem of loss of vertical deflection with the line offset from center suggests a cold solder connection in the vertical sweep circuit or in the power supply to the vertical sweep circuit. Most service shops should be able to fix.
6/2/2010 1:30:17 PM • LaCie Electron... • Answered on Jun 02, 2010
Turns on, no video.
How do you know it's recognizing the input? Black screen on a CRT monitor usually mean the horizontal output circuitry has failed impeding the flyback from producing high voltage. If this monitor is really important to you most reputable repair people still repair them. However, it may be overall cheaper in the long run to dump it and get an LCD monitor.
2/25/2010 7:22:13 PM • LaCie Electron... • Answered on Feb 25, 2010
Large VGA plug, smaller input on both IMacs'
DVi to VGA adapter
5/27/2009 11:05:02 AM • LaCie Electron... • Answered on May 27, 2009
Lacie 19" Electron Blue - Black screen with a brilliant white line across
I have 2 of these monitors and have this problem. I was so frustrated turning the monitor off and on until the white line disappeared that one day, I punched the screen. And it worked! So now whenever this happens (about once every other day) I use my palm and smack the lower left corner of the monitor until the white line disappears. I like the color on these screens so I don't want to replace them until I have to. I will NOT buy another Lacie though.
4/17/2009 6:26:21 PM • LaCie Electron... • Answered on Apr 17, 2009
Intermittent problem
Could be dry solder near vertical Ic and horizontal Output Transistor.Resolder components mounted on heatsinks.
Samir.
9/25/2008 7:36:06 PM • LaCie Electron... • Answered on Sep 25, 2008
Electron 19 blue 3 outer screen
Download this monitor test [url]http://www.iiyama.com/Download/documents/ice_pages_documents/21/MonTest_2_1.exe[/url] and click on 'convergence' Now manually change the convergence setting of your monitor with the onscreen buttons to align the red/green/blue lines
6/5/2008 10:27:54 AM • LaCie Electron... • Answered on Jun 05, 2008
Will not stay on
Under normal circumstances, a computer monitor will not remain powered up if it is not receiving a signal from the cpu. Whether or not this is the problem in your case is difficult to say. First steps would be to check all the cable connections to the monitor and cpu, and if that doesn't solve the problem, try another monitor with your cpu to see if it truly is your monitor that is bad or if what you describe is just a symptom of a larger problem. Good luck!
1/5/2008 2:13:24 AM • LaCie Electron... • Answered on Jan 05, 2008
No Green
Check the crt board and follow the green signal path, could have a shorted transistor or a resistor out of tolerance on that line, check all the components on that line
2/17/2007 11:08:54 PM • LaCie Electron... • Answered on Feb 17, 2007
I need to know how to do a factory reset on a lacie 4Big Quadra enterprise.
  1. Disconnect all cables from the device.
  2. Press and hold the "reset" button (located on the rear panel) for about 10 seconds.
  3. Wait for the device to restart and initialize. This may take several minutes.
  4. Reconnect the cables to the device and try accessing it again.
Note: It's recommended to backup all data stored on the device before performing a factory reset, as all data will be lost during the reset process.
2/11/2023 5:07:18 AM • LaCie Computers... • Answered on Feb 11, 2023
My LaCie Porsche Design 8TB Hard Drive wont receive power
Please check the link https://www.youtube.com/watch?v=VrhHzRDaXik
12/8/2022 5:19:01 PM • LaCie Computers... • Answered on Dec 08, 2022
LaCie Electron 19" CRT Monitor Logo
22 questions posted
Top LaCie Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Steve Sweetleaf
Steve Sweetleaf
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Electron LaCie
  • Electron LaCie
Most Popular Question
turns no video
  • Computers & Internet
