20 Most Recent JVC GR-SXM920 Camcorder Questions & Answers
Request the wiring diagram directly from JVC.
JVC GR-SXM920... | Answered on Oct 13, 2017
Brendon, The supply side tape guide can jump out of its track and cause the mechanism to lock up. The load motor is trying to load the tape but cannot, so the load motor driver "times out" and displays the E02 error you're seeing. If you can get to it, try reseating the guide into its track, be careful not to scratch or touch the drum assy located right near the guide track. Good Luck, I hope you can resolve the problem. Joe Weibel customelectronics.org
JVC GR-SXM920... | Answered on Oct 10, 2010
Please click on the below link to check out the battery.You can buy from any of these websites i highly recommend the first one.When you scroll down in after opening the first link you will see a list of batteries .They all are for your model only the price is different and stores.
The other 2 links below i mean the second and third will display the battery for your model on the front page and below you will see what model it supports.
http://www.epinions.com/reviews/pr-Camcorders_JVC_GR_SXM_920_S_VHS_ET_S_VHS_C_VHS_C_Camcorder_GR_SXM920
http://www.star-battery.com/CAMCORDER_BATTERY/JVC/VJV002.htm
http://www.camcorder-battery.org/JVC/BN-V11U-20H(4200).HTM
If you need any more help let me know
Thank you
JVC GR-SXM920... | Answered on Aug 04, 2009
Hi...
If you want to find a Power Adaptor you can find that adaptor in ebay you can also buy trough paypal. Just visit this site www.ebay.com
Thanks for using fixya.
Regards
PCmania
JVC GR-SXM920... | Answered on Aug 03, 2009
Nope, that camera only has S-Video and composite video outputs. IEEE1394 is also known as firewire. Newer camcorders will connect via firewire. You will need a video capture card for your computer. Either an internal card or a USB version. Then you can record the video onto your computer.
JVC GR-SXM920... | Answered on Mar 09, 2009
You need a video capture card that supports analog inputs. Connect the video and audio out jacks from the camera to the computer. You will need some sort of software also. The Movie Maker software that comes with Windows XP would work.
The little cord that came with the camera will not transfer the video.
JVC GR-SXM920... | Answered on Mar 08, 2009
you need ieee 1364 data transfer (firewire) just got one from ebay everything you need £5.00 easy to set up
JVC GR-SXM920... | Answered on Jan 29, 2009
HI SIR the fault is caused either by the take up or supply reel in the camera they are not rotating when the tape is inserted.maybe A defective tape or hung reel brake can cause this issue.or maybe a bad loosen guide of the tape path is lame , Try replacing the tape, if this does not resolve the problem you may need to seek professional service to have the reels checked. thanx and plz try to rate and remember i am here just to help u thx
JVC GR-SXM920... | Answered on May 08, 2007
Take camera and its battery to a camera outlet, ask them to check the built-in rechargeable battery.
Most outlets will help you with this, as its likely that if the battery has failed, you'll buy a replacement from the same dealer.
JVC GR Video... | Answered on Nov 13, 2017
JVC GR-SXM920 Camcorder Logo
23 questions posted
Top JVC Video Cameras Experts
Ekse
Larry Stiles
Larry Stiles
Al Rush
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
View Most Popular
GR JVC
  • GR JVC
Most Popular Question
jvc error code 02 safeguard mode
  • Video Cameras
