20 Most Recent
Sony Dvcam DSR-390P DV Digital Camcorder Questions & Answers
3ccd tape gs35
the play button is at the back,were the REC button is.to play back you will pres the gear up and down to stop and back wared towards the left is the rewind button finally the forward is the other button towards rihgt handside
Erro Code 02-674
my sony dsr 570
displays error 02674 how can i solve the problem
My cam is a sony dsr-390
Error code 91-258 is described as follows..
91- Microcomputer and its periphery device error
2- THREADING
5- S side reel FG
8- Detected abnormal current
Your camera got mechanical problem with Supply Reel and failed to load tape.
Er 95-120 what can i do?
This Error 95-120 it means error of digital data (2) input from the RC IC (DPR-141A board/IC310) to the NFL IC (DPR-141A board/IC505).It will only come if had drop it or u had bang when u where using it.
checked all the flat cable.
Error 91-13F
warning light flashing error 91 on my dvcam dsp 500 what can i do?
I got the errormessage: 95-753 DSR-1500A
the error you have is the communication error between SPCON and OUT-DSP. usually happens if its a bad cable....it is the cable that u have to check....
regards
iversh
