20 Most Recent
JVC GR-DVX400 Mini DV Digital Camcorder Questions & Answers
I can not tranfer video files from JVC GR-DVX
If you have a DVD recorder/player with DV in put, you can buy a FireWire 4 pin male cable from a good audio/video shop which can connect to the DV socket on the camcorder. I got mine from Maplins only last week and at last I am saving the tapes to DVD.Follow the DVD recorder booklet instructions and note every time you stop recording it will be saved as a separate file.
"04" error message when running on battery yet
Error code 04 shows problem of video head motor (drum fg signal) that either video head motor stop rotating or running too fast, this condition activates emergency mode and camcorder shuts down for safety.
Camera will take apart to inspect possible cause of problem and local camera repair shop will help you to fix this problem.
Hope these info will help you.
Thanks.
Cannot connect via DV out
dv out ? is not same as firewire ( check your
owner ' s manual ) but you do have usb - if
no video there , then accessing jvc user site
is your next best move ;
Error displayed
look for a small pinhole and insert a pin to reset the device. if no success, then slowly heat the device with a hair dyer.
Why won't my digital camera charge via USB anymore?
Take camera and its battery to a camera outlet, ask them to check the built-in rechargeable battery.
Most outlets will help you with this, as its likely that if the battery has failed, you'll buy a replacement from the same dealer.
