20 Most Recent
Sony Handycam CCD-TRV40 Camcorder Questions & Answers
Moisture error code sony ccdtrv40
I've had this before. It usually occurs when go outdoors from an air conditioned space. Moisture condenses on the headwheel which will cause the tape to stick... and THAT will make a real mess! If you're in a hurry, remove the tape cassette leaving the camera open, and use a hairdryer on LOW to dry out the inside of the unit. Then allow the camcorder to cool down (not in the cool or air-conditioned room) before you use it. In the future, you should take the camera out of the cooled area still in the bag several hours before you intend to use it. To hurry things along a bit, you can put in a sealed plastic bag indoors and then bring it up to temperature, but don't open the bag until has reached the temperature of the space in which you will be using it.
When i select the power
If the memory card came with the camera, I would suggest checking the little metal sensors on the memory card to be sure they are flat and in good condition.
Also, be sure the memory card is being installed correctly. Some of them go in (what I would call) sideways, and some up-side-down. If the memory card does not go into the slot easily, then try another way.
If you purchased the card separate from the camera, check to be sure it is the correct one. There are so many different options when buying memory cards. Even when they seem to look just alike, some are specific to certain cameras or types of quality and types of media you want to record on them. This determines the memory card formatting, and not all formats go with every camera. (I found that out the hard way.)
My sony Handycam video 8 ccd-trv40 will no longer
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Loading tapes
I had the same Problem. My Solution was i open the camera, then i take the batery away. I put the tape into and close the camera, then i put the battery into and the camera close with the tape
DCR TVR18E Sony
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of
your hand. Eject the tape and reinsert. You may need to do this a
couple of times.
Sony DCR-DVD200 camcorder not turning on after trying to fix it.
The best thing you can do now is to take it to a specialist and get them to do the repairs. Camcorders have a lot of electronics in them and can be easily damaged if your a not an experienced repairer. You might also have to consider that this camcorder might not be repairable.
Blue screen on TRV260 playback
TRV260 nail-polish head attack:
eek.
Acetone is a powerful solvent capable of dissolving plastic parts, plastic gears, housing and insulation.
Besides that, it leaves a residue of microscopic crystals which have probably contaminated the highly-polished metal head drum.
Not to mention gumming up the bushes and bearings.
With your next camera, rather use a head-cleaner DV-tape.
