20 Most Recent
JVC GR-DVF21 Mini DV Digital Camcorder Questions & Answers
I have a gr-dvf21 camcord that I want to use on my
If you can buy the tuner card, and do the recording. The best tuner card is from WinFast TV 2000 XP. It has video in, capabilities and recording is easy. It not even expensive and even you can edit the video in a professional way. i have done on many occasions and found out to be very reliable. Regarding to the camcorder, you have, if possible get the software driver and load in your pc. Read the instructions carefully and try to use it.
I get no playback from
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
What wire can i use to connect it to my computer?
You will need a firewire cable and a firewire port on your computer. If you don't have such a port then you can buy a pci firewire port. The firewire port looks like a usb port but its slightly bigger and on the one end is forming an angle.
Please see this link for details and photos.
Firewire Cable
E04 Error
Eject tape leaving cover open and remove battery. Re-insert battery and re-insert tape also leaving cover open. Keep repeating this process until eo4 message disappears. This worked for my GR-DVL100e after about four repeats. After getting your camcorder operational, they say it is good practice not to leave tape in camcorder when not in use.
E04 Error Message
Here's what i found. I was able to clear the message by opening and
closing and ejecting the cassette. I also had to play with the battery
at the same time. Keeping the cassette door open and then pulling out
the battery. After is did this a couple of times i got the message to
clear. I too haven't used my camcorder for some time and now that the
error message has cleared the camcorder tells me that i need to clean
the heads. Hope this helps. Below is the message i found that pointed
me toward ejecting the cassette. Good Luck, i'm off to buy a tape head
cleaning cassette. An error indication (E03 or E04) appears. - (E03 or
E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a
malfunction of some kind has occurred. In this case the camcorder's
functions become unusable. - Eject the cassette once and re-insert it,
then check if the indication clears. When it does, you can resume using
the camcorder. If the indication remains, consult your nearest JVC
dealer or service center
Why won't my digital camera charge via USB anymore?
Take camera and its battery to a camera outlet, ask them to check the built-in rechargeable battery.
Most outlets will help you with this, as its likely that if the battery has failed, you'll buy a replacement from the same dealer.
