20 Most Recent
JVC GR-AXM225 Camcorder Questions & Answers
Zoom button
You cant fix it by yourself. call for service.
SAFEGUARD MODE
The most common problem is that the belt for the center pulley comes off. The best fix is to replace the center pully because it is out of tolerance allowing the belt to jump off. Do you have an E03 error code on the screen? This is not a simple repair. The sequence involves a total disassembly, removal of the main board, removal of the mechanism, removal of the mechanism board and cassette-up basket, replacing the center pulley, reinstalling the belt and entire reassembly in reverse order. If you haven't done it before, even as a pro, you're in for a treat...Good luck, magic seadog
Why won't my digital camera charge via USB anymore?
Take camera and its battery to a camera outlet, ask them to check the built-in rechargeable battery.
Most outlets will help you with this, as its likely that if the battery has failed, you'll buy a replacement from the same dealer.
