20 Most Recent JVC GR-AX230 Camcorder Questions & Answers
http://www.amazon.com/Maxell-290060-Mechanical-VHS-C-Adapter/dp/B00012F6A6
Go to the above link to find this part from Amazon.com, it is also available at Wal-Mart, Best Buy, Radio Shack or other online vendors. Cost should not be more than $15. It is called a VHS-C adaptor cassette.
JVC GR-AX230... | Answered on May 04, 2011
You cannot connect an analog camera to a USB port. The signals are completely different. There are no cables available to join these incompatible connectors together.
However, you can get videos from this camera, or any analog video source, into a computer. You just have to play them into an analog interface port. These are available as expansion slot cards for a PC. They will come with software to digitise the video input and record it to a file. You don't need any "driver" related to the camera, it is just a video signal. The connecting leads will be standard RCA signal plugs, like on the back of a HiFi amplifier. You probably already have a lead for this.
JVC GR-AX230... | Answered on Nov 01, 2010
open the door and peek inside. is there a roller guide falling out?
JVC GR-AX230... | Answered on Jul 20, 2010
Bad Battery most likely. I take it you don't have a spare battery to rule out a bad battery?
JVC GR-AX230... | Answered on Apr 28, 2010
E03 means the motor drive has failed.The damage is permanent. The camcorder GR-AX5 is too old to repair.Recycle it and buy a new one.
JVC GR-AX230... | Answered on Nov 11, 2009
can i buy it off you???
JVC GR-AX230... | Answered on Feb 17, 2009
Could be a drum or heads. Looking at a $120 repair
JVC GR-AX230... | Answered on Dec 31, 2008
All I wanted was to buy a charger, so I don't need your help. I found one. thanks.
JVC GR-AX230... | Answered on Jul 19, 2008
try to clean the video head using a blank new tape.....just forward or rewind it until the head been clean cause using a head cleaner is damaging the head,the cleaner is so rough that why i cannot recommend of using that...if it still the problem is like rainy picture...the problem is the head it need to be replace but if the cost is to high you think you better buy a new camera....
JVC GR-AX230... | Answered on Aug 26, 2007
Take camera and its battery to a camera outlet, ask them to check the built-in rechargeable battery.
Most outlets will help you with this, as its likely that if the battery has failed, you'll buy a replacement from the same dealer.
JVC GR Video... | Answered on Nov 13, 2017
JVC GR-AX230 Camcorder Logo
21 questions posted
Top JVC Video Cameras Experts
Ekse
Larry Stiles
Larry Stiles
Al Rush
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
View Most Popular
GR JVC
  • GR JVC
Most Popular Question
want join jvc compact vhs gr ax2 from
  • Video Cameras
