20 Most Recent
Hotpoint 6.92 cu. ft. / 196 liter Upright Freezer FZM80 Questions & Answers
The Freezer is a FZ150
flashing red light indicates it's too warm in the freezer.Check
the compressor to make sure it is running? if it is then your low on
freon.Check if fan near the compressor is running?If still the problem persist switch off the freezer for 24 hours and check for it is fully defrosted.This warm in freezer occurs due to block in air flow due to defrost of ice.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
RED HIGH TEMPRETURE LIGHT IS ON.WHAT IS THE USUAL
if the temperature rises above 30 degrees then this is to let you know that there is a problem.
it could be one of these problems:
dirty condender
condenser fan not running (if available)
freezer fan stop working
compressor valves bad
lost of freon (under charge)
defrost heaters not working
bi-metal t'stat not working
timer bad
if you need more help let me know
Hotpoint FZA80 freezer: water leaking
There's a drain hole inside the freezer in the bottom of the back wall ;probably is clogh .Put hot water into it to melt the ice and then blow it with air pressure;keep it clean pouring bleach throught it every 2 or 3 months.
HOTPOINT FZA80 FREEZER
Red light is indicating temp is too high, this can be caused by a variety of reasons.
You need to call an engineer to sort the problem out.
Top half not freezing
If this is not a frost free unit , it probably has a freon leak. This is usually not worth fixing in a deep freeze. If it is a frost free unit the fan could be bad. This is an easy repair.
What do the control buttons do on a Hotpoint Ice Diamond R134A do please?
Could you please recheck for the model number. R134A is a reference to the coolant used in the freezer mechanism.
Orange is often a reference to the 'Fast Freeze' function being turned On. Green is showing the freezer unit is at the correct temperature. Red is warning the freezer is Too warm. Some freezers are fitted with an 'Economy' function where the freezer can be run at a lower power level when not used regularly such as when on holiday.
8/2/2022 5:09:29 PM •
Hotpoint...
Answered
on Aug 02, 2022
My FFA70 fridge/freezer is causing my circuit
kevinmdoyle... Hello and welcome to FIXYA,
Yours is a UK model... so I (usa) can't help you
on SPARES (motor start capacitor) ...
however
Circuit breakers do go bad...!!
(easiest & cheapest to check first)
MUCH Easier to test the idea than you would imagine:
- Shut OFF your
main breaker.
- Open your panel & swap the wire with an EQUAL breaker
- Tag the wires (to restore when finished trouble shooting)
- Restore the main breaker (wait & see)...
and don't forget to clean that CONDENSOR
per owner manual instructions.
If the failure persists... RESORE the BREAKERS.
and
HOPE it is the START CAPACITOR on your compressor.
Carnac the Magnificent
1/15/2018 3:11:44 PM •
Hotpoint...
Answered
on Jan 15, 2018
