20 Most Recent Hotpoint 3.6 cu. ft. / 102 liter Upright Freezer RZA21 Questions & Answers
0answers
Too cold
Be the first to answer 1/31/2014 3:19:26 AM • Hotpoint 3.6 cu.... • Posted on Jan 31, 2014Be the first to answer
I need a manual for my hotpoint fridge/freezer
http://userguides.50webs.com
The site above will have this manual.
8/27/2013 3:29:23 PM • Hotpoint 3.6 cu.... • Answered on Aug 27, 2013
0answers
How is it best to defrost this as it is very clogged up with ice?
Hello Cathy,the best way to defrost that little refrigerator is obviously turn off the unit and use a blow dryer and use it to melt the frost.GENE
11/30/2011 8:02:16 PM • Hotpoint 3.6 cu.... • Answered on Nov 30, 2011
Water gathering in pipe in
Hi you will find this is a common problem bits of food get into this outlet and it gets blocked you should have got a small tool with the freezer when you bought it if not use a small screwdriver or smilar item to unblock the hole and you will find this will solve the problem
3/21/2011 2:16:25 PM • Hotpoint 3.6 cu.... • Answered on Mar 21, 2011
Compressor works intermitently
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
1/25/2011 1:38:24 PM • Hotpoint 3.6 cu.... • Answered on Jan 25, 2011
The red light is on for high temperature tried to
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
8/24/2010 6:34:26 PM • Hotpoint 3.6 cu.... • Answered on Aug 24, 2010
High Temperature Light
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
4/21/2010 10:12:13 AM • Hotpoint 3.6 cu.... • Answered on Apr 21, 2010
The top elements quickly become frosted on my RZA
either you evaporator fan isn't working or your low on freon in unit
10/11/2009 11:40:45 AM • Hotpoint 3.6 cu.... • Answered on Oct 11, 2009
The compressor works for a few seconds but then stops. The freezer is over temperature.
Check the condenser fan motor (next to compressor) make sure it is running. Next change relay (inside black box) on compressor.
4/27/2009 12:47:29 PM • Hotpoint 3.6 cu.... • Answered on Apr 27, 2009
Condensation on base of Hotpoint R134a upright freezer
sounds as tho you have an insulation breakdown. no repair except to refoam - and that is difficult to do
8/9/2008 3:57:59 PM • Hotpoint 3.6 cu.... • Answered on Aug 09, 2008
What do the control buttons do on a Hotpoint Ice Diamond R134A do please?
Could you please recheck for the model number. R134A is a reference to the coolant used in the freezer mechanism. Orange is often a reference to the 'Fast Freeze' function being turned On. Green is showing the freezer unit is at the correct temperature. Red is warning the freezer is Too warm. Some freezers are fitted with an 'Economy' function where the freezer can be run at a lower power level when not used regularly such as when on holiday.
8/2/2022 5:09:29 PM • Hotpoint... • Answered on Aug 02, 2022
2answers
My Hotpoint fridgefreezer is freezing way below the recommended temp what cqn I do??
Inside the fridge is a adjusting knob.
1/27/2019 8:31:03 PM • Hotpoint... • Answered on Jan 27, 2019
What is the a2 error code on a hotpoint fridge / freezer?
A2 error Hotpoint fridge what is it mean I want to do
1/26/2019 7:38:51 PM • Hotpoint... • Answered on Jan 26, 2019
My hotpoint ff187 fridge/freezer is making a
clean the door rubbers and sides this sometimes fixes the problem as the seals are not closing properly and the fridge freezer thinks you have left the door open.
2/9/2018 10:41:03 AM • Hotpoint... • Answered on Feb 09, 2018
My FFA70 fridge/freezer is causing my circuit
kevinmdoyle... Hello and welcome to FIXYA, Yours is a UK model... so I (usa) can't help you on SPARES (motor start capacitor) ... however Circuit breakers do go bad...!! (easiest & cheapest to check first) MUCH Easier to test the idea than you would imagine: - Shut OFF your main breaker. - Open your panel & swap the wire with an EQUAL breaker - Tag the wires (to restore when finished trouble shooting) - Restore the main breaker (wait & see)... and don't forget to clean that CONDENSOR per owner manual instructions. If the failure persists... RESORE the BREAKERS. and HOPE it is the START CAPACITOR on your compressor. Carnac the Magnificent
1/15/2018 3:11:44 PM • Hotpoint... • Answered on Jan 15, 2018
Why is my hotpoint upright freezer making a loud pulsating noise
Hotpoint is made by GE so it may break down soon. I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
12/17/2017 4:29:44 PM • Hotpoint... • Answered on Dec 17, 2017
Hotpoint 3.6 cu. ft. / 102 liter Upright Freezer RZA21 Logo
25 questions posted
Top Hotpoint Freezers Experts
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Stan Ford
Are you a Hotpoint Freezer Expert? Answer questions, earn points and help others
View Most Popular
Hotpoint Freezers
  • Hotpoint Freezers
Most Popular Question
info freezer control rza21
  • Freezers
