20 Most Recent Sony SDM-HS73P 17" LCD Monitor Questions & Answers
0answers
What do i do when the dialogue box reads 'cable disconnected burn in mode'
Get monitor out of burn in mode by unplugging the power to monitor then while holding down the power button on monitor plugged in the power cord to the monitor all while it is connected to a running computer. Turn the monitor off with the power button. When press the power again the burn in mode should be gone and the monitor should display the computer
4/24/2015 12:26:16 AM • Sony SDM-HS73P... • Answered on Apr 24, 2015
2answers
Black screen flashes after initial power up
Possibly the backlights have failed. The screen part may be working normally. Get a bright light close to the front of the screen, see correct image faintly. Commonly it is failure of the high voltage inverter circuits that power the backlight fluorescent lamps. You can probably buy replacement circuit or repair the one you have. I have done this on another model. You need to search the web for experience of the same model. RDL.
2/13/2015 12:23:12 PM • Sony SDM-HS73P... • Answered on Feb 13, 2015
There is a thin bright green line on my monitor
my computor monitor keeps turning a very bright green, When it does I cannot see anything thing clearly, yellow and reds look the same. how do I fix it.? Please help Thank you
8/28/2013 2:36:56 AM • Sony SDM-HS73P... • Answered on Aug 28, 2013
The monitor won't get power
have you tried different outlets?
2/6/2013 11:28:56 AM • Sony SDM-HS73P... • Answered on Feb 06, 2013
Sony monitor
One possible cause of the this problem is the bad lamp assemblies due to poor soldering works, please see the pictures here: http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/
The repair person should also look for bad caps in the power supply section.
You will need test lamps to test and verify if the lamps assemblies are good or not.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
8/26/2011 11:48:57 PM • Sony SDM-HS73P... • Answered on Aug 26, 2011
Monitor sony sdm hs73p come black in few seconds
This SONY series are known to have bad lamp assemblies due to poor workmanship.
http://s807.photobucket.com/albums/yy352/budm/SONY/Sony%20SDM-HS73/
You need to also check the caps in the power supply, etc.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
7/12/2011 4:32:48 AM • Sony SDM-HS73P... • Answered on Jul 12, 2011
No picture Display when turned
This is not an inverter problem. The inverter only powers the fluorescent lamps in the back of the LCD panel.
It is probably a fault in the LCD data decoder circuit or a failing connector between the decoder circuit board and the glass LCD panel. If you took it in to a shop, they would probably charge you a full hour's labor minimum - compare that with the price of a new LCD monitor.
5/25/2011 3:13:08 AM • Sony SDM-HS73P... • Answered on May 25, 2011
Will not retain screen image. Flashes the content
It appears you may have a bad backlight. If you can see the picture content with a strong light shining at an angle to the screen while it is dark, then it is definitely the backlight. Most sets shut down shortly after getting a failure signal from the backlight inverter although you do not mention that happening.
The backlight uses two or more Cold Cathode Fluorescent Lamp (CCFL) tubes, and they'll have the same flickering as a failing standard fluorescent tube. If the light has a pinkish cast to it, this is a common sign that one or both of the tubes is bad. You may see the flashing on the top or the bottom and the other half of the screen will be dark; this means one tube is dead and the other is dying.
5/25/2011 3:08:36 AM • Sony SDM-HS73P... • Answered on May 25, 2011
The screen has a dark green tint and cannot be
Take it in for repair seems to me that you have done all that you could to fix this monitor it is a flat maybe worth the repair if the repair is slightly less or more I would consider spending the green on a new one they are getting down in price. Thanks for using FixYa! John
4/2/2011 9:08:26 PM • Sony SDM-HS73P... • Answered on Apr 02, 2011
Screen goes black while power button is on i turn
Common problem with is SONY 17" and the 19" are due to fail lamp assembly as shown in my pictures here which will be the worst case. You will need to check the other parts in the set first.
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS93/
You will need test lamps to verify.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series. Please leave rating if it helps.
1/9/2011 4:15:13 AM • Sony SDM-HS73P... • Answered on Jan 09, 2011
What do you do when
Try to see if your signal cable from the systems unit is connected to the LCD. If it is connected, then that means that your VGA is not sending any signal, try connecting your LCD to another system unit and see if it works.
1/8/2011 9:02:02 AM • Sony SDM-HS73P... • Answered on Jan 08, 2011
0answers
tip
If there is discoloration then follow this
The discoloration problem is due to the near by magnetic field appliances like speakers which are very near to monitors ...
so what you have to do is just keep some distance to the monitor from the speakers and other magnetic appliances and then press menu button & just give degauss..
Screen keeps on turning black, even though the
It may have bad lamp assembly as shown in my pictures here:
Also check the DC filter caps.
If you are going to DIY and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
10/13/2010 12:38:29 AM • Sony SDM-HS73P... • Answered on Oct 13, 2010
Hola,mi monitor SONY SDM-HS
no estoy seguro pero creo que el problema esta en el circuito integrado GM2121 que esta precisamente en la placa que mencionas...ya que a pocos minutos de estar encendido recalienta mas de lo normal...
9/10/2010 12:35:56 AM • Sony SDM-HS73P... • Answered on Sep 10, 2010
Switch not working after few
May I ask exactly what it is not doing? Flashes on then goes off?
This monitor has known problem with the CCFL assmblies.
Best to get new switch board assmbly if that is the case, I never run into one with broken switch yet in thsi model.
You can get this tactile switch from www.mouser.com or www.digikey.com just have to match the foot print and height.
8/12/2010 7:58:26 PM • Sony SDM-HS73P... • Answered on Aug 12, 2010
Sony SDM-HS73P 17" LCD Monitor Logo
96 questions posted
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
SDM Sony
  • SDM Sony
Most Popular Question
upgrade adobe flsh player
  • Computers & Internet
