20 Most Recent
JVC GR-SXM58 Camcorder Questions & Answers
Problem with jvc gr-sxm58
Do you happen to try with another tape? if so, it needs repair, mostlikely the capstan motor need to change and it needs hinger skill to do this, since you have to adjust it after replacing.
Jvc GRSXM58EK
You could have dirty heads. If the tapes weren't stored properly and were exposed to high humidity and tempreture the oxide could have loosened allowing it to plug the video head. New tapes will not solve the problem. Once the head is dirty it must be cleaned. Here is a website which explains it as well as I could and they even have pictures: http://www.bealecorner.com/trv900/trouble/cleaning.html
Another tip is to only use top quality, name brand tape. Cheap tape will shed oxide and require more frequent cleanings. Cleaning the heads is probably the most overlooked item with camcorders. If you are not confident doing this job take the camcorder to a reputable shop. Good luck.
Why won't my digital camera charge via USB anymore?
Take camera and its battery to a camera outlet, ask them to check the built-in rechargeable battery.
Most outlets will help you with this, as its likely that if the battery has failed, you'll buy a replacement from the same dealer.
