20 Most Recent
Hitachi DZ-MV730A DVD Camcorder Questions & Answers
Hitachi DVD mv730 cannot read disk
I have had this problem and either the disc is not formated or your battery was to low(bad battery) and I have also had bad discs. Just like with blank cds. Hope this helps!
9/5/2021 9:11:28 PM •
Hitachi...
Answered
on Sep 05, 2021
I cant playback a disc that isnt scratched or dirty
I have the same problem with trying to finalize a disk....It says the disk is scratched and must be cleaned ...There is no scratches on the disk and everything was fine before this problem...Can you help?
3/5/2016 8:00:53 PM •
Hitachi...
Answered
on Mar 05, 2016
User Manual
Hi, I have the owners manual in a PDF file if you want it. Just post your e-mail address and I will forward it to you. All the info you are asking for is in this manual. Good Luck
4/16/2014 4:43:16 AM •
Hitachi...
Answered
on Apr 16, 2014
Do I HAVE to use Maxell dvd-r
Provided you check that what you are buying is DVD-R or DVD-RW (as opposed to +R or +RW), it should work.
Best thing is probably to buy one or two and see how you get on.
There's not many places make DVDs - and an awful lot of badge engineering goes on. You could download a useful bit of freeware from http://dvd.identifier.cdfreaks.com/ to help you find out which factory your Maxell discs have come from - and which of your cheap alternatives actually hail from the same stable.
A.
10/21/2012 12:38:30 AM •
Hitachi...
Answered
on Oct 21, 2012
I have an Hitachi DZ-M750ma camcorder. I need to
Attach battery look like thing on where you attach battery in camcorder and DC pin will go in AC Charger as it has DC jack, check below image that will help to get better idea.
Thanks.
7/25/2012 8:03:52 PM •
Hitachi...
Answered
on Jul 25, 2012
NEED FINALIZING DVD
Hi!! My husband just sat down and finally figured this out,
You have to use disc navigation, then wait for the thumbnails to show up and then push menu and scroll down three times to the disc, and then choose finallize and then tell it yes. You do have to have it plugged into the a/c adapter tho in order to do this for some reason.
Hope this helps,
Gin
Have a Creative Day!!!
7/25/2012 7:52:34 PM •
Hitachi...
Answered
on Jul 25, 2012
It tells me card error?
Make sure you truly have an SD card. If it's 4GB or larger then it's actually an SDHC card. While it fits into the slot it is electronically incompatible and will not work in this camcorder.
4/28/2012 5:48:40 PM •
Hitachi...
Answered
on Apr 28, 2012
I am using an sd
Sorry, but as far as I know, Hitachi camcorders cannot record video directly onto an SD card. You have to set the camcorder to DVD. It can only record video and pictures on a DVD, and only pictures on an SD card.
2/5/2012 9:09:05 PM •
Hitachi...
Answered
on Feb 05, 2012
Freezes
I had the same problem - you are (as I was) turning off the camera too soon after you hit the stop button after recording a scene. Wait until the word "disc access" appears (about 5 seconds after you hit the stop button. This "marks" the end of the scene. I just don't know how to edit that scene out or if it will delete it out. I know after finalizing the disc that scene will pause for a while (10 to 20 seconds even) when you watch it through the DVD player to the TV.
10/27/2011 12:12:13 AM •
Hitachi...
Answered
on Oct 27, 2011
Tried to eject disc from
Hi Igniscol,
In this case you can try using a direct plug of AV adapter, this will possibly supply appropriate power and hence can help you eject the disc.
If the above solution does not work then press the reset button behind the LCD screen and it should solve the problem.
Hope this helps..:)
9/9/2011 1:14:02 AM •
Hitachi...
Answered
on Sep 09, 2011
