20 Most Recent
Dell E153FP 15" LCD Monitor Questions & Answers
I have a Dell cpu and a Dell flat screen monitor .
try to hook it up to a different monitor first to verify its the monitor problem and not a bios, driver, or pc problem. if an alternate monitor works, then you know something happened to you original display! If the alternate does not work either, but it does work other machines, then its something else: graphics card, wiring, etc. hope this analysis quickens your solution.
Dell monitor power button is flashing
I had the same problem. After buying another monitor and before throwing this one away I thought I would try plugging it in since it was sitting for a day. I still received the flashing light until I gave it a slight hit on the back side, it is now working fine.
No power
check your powers suplly waltage and earthing properly.change your power cable of lcd monitor.
reconect it.fix it proerly.then try u can do it.
Dell Flat Screen off/on switch broken
Mohons, Get with the the program, will ya!! A video clip is worth a thousand words!! Try a search at YOUTUBE for the longer 6 to 10 minute video clips of "LCD monitor disassembly" and "LCD monitor repair". Here is a clue. "Parting the rear cover from the front plastic bezel is the hardest part." Go watch some video. You will be glad you did. And while your inside the monitor, why don't you check the "switch-mode-power-supply board for any swollen and/or leaky electrolytic filter capacitors! Do you have an OHM-Meter or DVM to check the switch? Bye for now. 12fixlouie
ps. could be SMPS is not "listening" to a GOOD switch!
What is tha main problem for no display
The main problem is usually the cable.
Next is video card driver.
Next is power supply for the monitor.
Questions to ask:
Does the power light come on?
Does it work with another computer?
The brightness/contrast box keeps popping up
There might be dirt underneath or close to the buttons.Try some compressed air to remove any dirt that might be there.Remember to unplug the monitor before you try to service it.
Good Luck
NO SOUND
THe round black one is for a power supply really big block one that need to be plugged in. Is your power light next to the volume button on.
