20 Most Recent
Xerox XG-71D 17" Flat Panel LCD Monitor Questions & Answers
Monitor goes on and off........seemed to come on
In your Windows XP
- Go to Start and click
- The Start menu will open
- In the start menu click settings
- In the settings select "Control Panel"
- The Window of control Panel click "Power Options"
- In the Power options you will find Display time settings. These are the time settings that determine the time like if your computer stay idle for 5 min, the display will shut down.
- I suspect that this time is set to be very low like if there is no activity on the computer such as key punching, typically happens when you are reading an e-book Windows will automatically shut down the display. So you can increase the idle time to say 7-10 minutes and/or a similar setting is "Put the computer to sleep". Try to carefully alter the time values and you will find a good settings that work for you.
If the above tip does not work then there is definitely something wrong with your monitor's hardware most probably the power supply. You need to check it with a repair shop.
Good Luck!
Xerox XG-70D
Remove the 2 screws near the bottom on the back.
Place the monitor face down on a towel with the 2 screw holes near you.
Push the grey plastic back cover away from you whil holding the glass front in place on the towel and the back will lift off easily.
Scepter monitor goes to sleep every 20 seconds!
You have a power supply going out in the monitor. You can check out some pictures on our web site at:
www.ccl-la.com/badcaps.htm If you can solder then you should be able to repair your monitor. Open the back of your monitor and look for the bad capacitors( the little aluminum parts with the tops popped open as seen in the pictures). Unsolder all the ones with the bulging tops and replace them with new caps. If you have questions just email me. If you don't want to do the repair yourself then we orrer a repair service, contact me for more info.
Buddy
Corporate Computer
www.ccl-la.com
Green power light blinks
open it up... whats the worst that could happen... see if the caps are fine... if they are bloated exchange them... if you need help doing so hit me up at abelino24(at)sbcglobal(.)net... I've repaired like three of these in the past few months.. its always the capacitors. they either get really hot and bloat or don't function if it gets too cold... so the solution if to get the right caps at 470uf / 25v and 220uf / 25v... hopes this helps...
No Power or responce when turned on
This is a Common problem MOST if NOT ALL, problems like this with this type of fault it is invairably a problem with the Power Supply, in the PSU Electrolytic capacitors dry out and often cause this type of exact problem... It is a relitively simple fix, by replacing the caps with new ones... Any good shop should be able to fix for a modest fee.. OR if ya know anyone handy with a soldering iron maybe they could do it for you there are generally about 4 - 6 to replace... in the PS section, just do them all to be safe.. Generally most LCD's problems can be traced back to a bad PSU... almost 80% of the "problems" I find in my shop are indeed this.
Colors flashing no picture
Did you have another monitor to verify the problem whether it is related with the Video card or the monitor itself?
HOW TO RESET FORGOTTEN PASSWORN ON A XEROX 7435
If the default username and password (admin/1111) are not working on your Xerox 7435 printer, you can try resetting the password to its default settings using the following steps:
Turn on the printer and wait for it to boot up completely.
Press the button with a wrench icon on the printer's control panel to enter the settings menu.
Use the arrow keys to navigate to the "Security" option and press the OK button.
Select the "User Authentication" option and press OK.
Enter the current password, if you remember it. If you don't remember it, leave it blank.
Select the "Reset User Accounts" option and press OK.
Select the "Restore Defaults" option and press OK.
Confirm that you want to restore the default settings by selecting "Yes" and pressing OK.
After you have completed these steps, the printer's password will be reset to the default settings (admin/1111). You should now be able to log in to the printer's settings menu using these credentials.
Xerox Workcentre 7535 LED's flashing repeatedly when powering up
Hai this is Arun. If your motherboard gets power but the computer not starting then there are two solutions :
- Unplug the wire that is coming from the power switch to the motherboard & plug it again.
- If it is still not starting, then remove your CMOS battery and insert it again in the motherboard.
Hope these steps may solve your problem.
Thanks.
