20 Most Recent Panasonic NV-DS65 Mini DV Digital Camcorder Questions & Answers
That weird noise you are hearing is the mode motor trying to drive the mechanism. On these units, in order to engage play, fast forward, rewind, etc there is motor (called a mode motor) the drives the mechanism into the different "modes". There is also a mode sensing switch that tells the machine when it has reached a certain mode. What has likely happened is that the mode switch has failed for whatever reason, so the mode motor is being driven beyond the normal positions for the mechanism. The short answer is that you will probably have to have a technician look at it for you.
Panasonic... | Answered on Jul 15, 2016
You will require the cable that came with the camera to be plugged into the TVS AV input sockets.
Al
Panasonic... | Answered on Nov 22, 2013
You will require a firewire cable.
Usually a 4 pin to 6 pin cable. 4 pin to camera 6 pin to computer, assuming you PC has a fireiwre socket.
PC computer have Movie Maker as part of the OS.
Connect with the above cable and you should be good to go.
Al
The NV-DS65 is a mindv camcorder manufactured by Panasonic. You can get the drivers on Panasonic's website (panasonic.com) or here: http://www.driverfiles.net/Cameras/Panasonic-(Matsushita-Matshita)/nv-ds65/download/page,sh,24262,563,17,.html
Panasonic... | Answered on Nov 12, 2013
This may sound daft BUT you have taken the lens cover off, have`nt you?
Panasonic... | Answered on Dec 28, 2012
Use a hair dryer to blow warm air into the unit. Do not heat the unit but allow only warm air to circulate so as to remove any dew formation within the unit that must allow the unit to reset the error.
Panasonic... | Answered on Jan 20, 2012
CCD Imager chip is defective in your camcorder that is why no live view in camera mode for fresh recordings.
CCD Imager is electronic device that converts an image into electronic signals and its necessary part of any digital camera/ camcorder, it should be replaced by technician because camcorder will take apart and soldering work is required.
Thanks.
Panasonic... | Answered on Sep 05, 2011
HI there.
My name is ib_yang. How can we help you?
Panasonic... | Answered on Aug 24, 2011
Reduction gear in mechanism is dampered,so it wont drive the cassatte holder,so repelace the reduction gear
Panasonic... | Answered on Jun 10, 2011
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Panasonic... | Answered on Apr 27, 2011
Panasonic NV-DS65 Mini DV Digital Camcorder Logo
137 questions posted
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Video Cameras
Most Popular Question
no picture
  • Video Cameras
