20 Most Recent
ViewSonic G90fb 19" CRT Monitor Questions & Answers
How to remove osd lock
you need to press together two of the buttons on the display, if you would post the brand and model of the display to me, or find your manual and go read it - part about osd lock, you will find how to unlock it, if you don't have a manual post me the brand and model and I'll check the manual for you on how to turn it off and on.
My PC "ViewSonic 15" "
Looks like a virus attack to some extent. Run a virus scan. If that doesnot work, then check the keyboard and replace it.
Blurry monitor
The monitor is going bad. It can be serviced but the cost to fix or adjust is not worth it. You may be able to adjust it yourself but A) you need to know what you are doing and B) Accept the risk of completly ruining the monitor or even worse electricuting yourself by accidentialy touching one of the high voltage circuits. A carry in service repair shop will charge about $125.00 to $200.00 to fix it. A new LCD flatscreen is a much better choice it will cost the same or less and will pay you back in time just from the energy savings. My condolences.
How to set the resolution on my va2226w
Setting the resolution.
1. Make sure that the monitor supports 1680 x 1050.
2. If you are running Windows XP or Vista, right-click the desktop screen and then go to "Properties".
3. Go to Display tab.
4. Change the resolution with your desired one.
Have great day!
'memory recall ok'
I got the problem solved. The other day i called up the viewsonic tech support, service engineer visited and changed the switches inside. the problem got solved. So call up the tech support of view sonic at (india)
We need the following details to create an RMA Request for your Product.
Once an RMA request is created our service Engineer will contact you within 2 Business Days to attend the call.
1.Customer Name
2.Phone no with STD code
3.Complete Address
4.Model and Serial No of Product
5.Description of problem
We can be reached on this email address or through phone on our Toll free No1800-11-9999 or Toll No:-011-26990006
Have a Great Day Ahead.
Thanks & Regards
ViewSonic India Technical Support
bye
Memory recall problem
call up n lodge compaint reg the issue, if in warranty its done free of cost. Nothing to worry abt it, just they wud come n change the switches of menu from inside, thats it, its a matter of 10 min.
1.Customer Name
3.Complete Address
Thanks & Regards
bye
Vjai
Viewsonic E53 monitor
Base on the information given to me.
I think your computer is on sleeping mode.
first thing check if the video cable is not loose connecting the pc.
because what would happend, if it is loos it would turn on and off at times.
The other thing you can do.
right click on the desktop.
go to properties
go to screen saver
click on power
adjust the time you want your monitor to shut off.
Viewsonic VX2835wm monitor that powers up with a good screen for a couple of seconds and then goes blank. I replaced the power board and it still does the same thing. Could it be the on/off switch?
FIRST WE DO NORMAL AND LATER TRUE CAUSE.
gee that is normal on all monitors and by Energy Star laws too.
the monitor if the PC is dead or in speed mode, shuts of in 15 to 90 seconds, all do, every one. the monitor has self sleep, all do. everyone ever made did. even back to CRT days.
and the OSD button goes dead after. that. too. fooling the untrained.
here is the first tests, NO PC connected at all
power on see power light glow correct color
then see Viewsonic splash screen push the menu button now. quickly, if button dead hold it for 10 to 15 second to reverse the button lock now, see OSD works.
if you test the monitor on a good PC not in sleep mode the but working PC, your monitor is ok.
this monitor is very very old, 2004?
it has CCFL back lamps not LED<
and all fully used CCFL lamps are now no good, used 8yrs a day at 5years are no good. that is why we use LED back lamps now.
this is what they do: all do , used fully.
1: goEs dead forever, (vast did)
2: INTERMITTANT . (BINGO YOU ) OR INVERTER DEAD.
3: DIM BULBS (like me. lol)
4 TURN YELLOW FOR WHITE screens.
5: STROBEs. (FLASHes)
AND A VERY EXPENSIVE SURE, THAT. AND LABOR.
3/2/2022 5:23:35 PM •
ViewSonic...
Answered
on Mar 02, 2022
Viewsonic VX2880ML 4K monitor, front vontrols won't work, help.
power on and power on led glows normal , not yellow or flash.
then this happens splash. attached, 2014 made.
then that tells you screen is NOT DEAD is it? now? here?
(PC is dead or missing)
- NO connections on 1 or more inputs.
- NO sync
- no signal
- OUT OF RANGE
and goes black screen NEXT,. if all that fails power supply is bad.
if all that works the menu button works for 15 seconds turned on with no PC, and also works on all PCs if connected to one that are all good and not sleeping. test the monitor on 2 PCs if confused.
3/2/2022 4:55:16 PM •
ViewSonic...
Answered
on Mar 02, 2022
My new Viewsonic VX monitor shows "no signal" when connected to computer.
that means just what it tells you
the PC is dead, PC video dead or video cable unplugged , dog chewed it , pins bent or plugged in wrong on 1 or both ends.
or monitor not selected to the correct input port (OSD)
PC power lamp glowing not amber or blinkikng
PC fans spin , PSU fan and CPU both
if PC has GPU card in PCI-express slot it must be use those ports only for video.
PC not beeping
PC not texting errors post.
PC not blinking codes on LED or caps lock or POST ERRORS !
NO PC told
PC dead.
PC not stuck in sleep mode , hold PC power button for 10 full seconds to end it, (cold boot that is)
test monitor on end good PC? yet?
3/2/2022 4:54:28 PM •
ViewSonic...
Answered
on Mar 02, 2022
Screen won't come on, on my Viewsonic VSR220
WHY DOES THIS SEARCH SHOW.The Viewsonic VSR220 no such thing.?Turn the monitor around, 180 and see the TAG sticker with real model toldno PC told , what PC is this?this ? VSD (D key is next to R) so huge typo"?https://www.viewsonic.com/eu/products/lcd/VSD220yes that is a PC (android)but can do monitor like duty. too.it needs service.if screen is dead, it has power problemsas the screen must at least show a viewsonic splash as power is turned on.try it on a 2nd room AC power jack yet:?if in warranty take it back to the storeor call viewsonic for help.the android PC can use an HDMI cable to a PC and works as a monitor.too.the manual states"4.5 Connecting to HDMI-compliant Devices via MicroHDMI InputHDMI (High-Definition Multimedia Interface) is a compact audio/videointerface for transferring uncompressed digital audio/video data. You canobtain the best user experience for video playback and gaming via HDMI.VSD220 is equiped with a micro HDMI input for connection to an externalHDMI-compliant device. You can connect your PC, notebook, Blu-ray playeror any other HDMI-compliant device to VSD220 for high-definition videodisplay."
2/16/2022 7:47:31 PM •
ViewSonic...
Answered
on Feb 16, 2022
