20 Most Recent ViewSonic VX924 19" LCD Monitor Questions & Answers
One of the background lights may have burned out.
ViewSonic VX924... | Answered on Jan 28, 2018
Try pressing the number 1 again. It should exit the OSD. While the screen is stuck with the OSD. Press the power button (blue) and push to turn it on again.
Hope this helps.
ViewSonic VX924... | Answered on Sep 15, 2014
Sounds like the unit needs repair.
ViewSonic VX924... | Answered on Aug 31, 2014
We do a lot of LCD monitor repairs and usually when you get the red tinted display it means the backlight tube is going out. This part is like a very small fluorescent tube just like in you office lamps. The tube is part of the display section and is very hard to replace. You can check the power supply first just to be sure. We have a dis-assembly/repair guide on our web site at: www.ccl-la.com/badcaps.htm If you find any bad capacitors you can change them and check but I would be it is the backlight tubes, if so just replace the monitor.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
ViewSonic VX924... | Answered on May 14, 2014
Check the below documentation for Circuit diagram
http://michaeljaylissner.com/archive/viewsonic/VX924-1_SM_1a.pdf
ViewSonic VX924... | Answered on Dec 25, 2013
"VGA monitor cable" usually - 15 pins.
ViewSonic VX924... | Answered on Dec 18, 2013
Two ways - use a thirteen pin connector (the one that looks like an old school printer cable) or HDMI
ViewSonic VX924... | Answered on Dec 16, 2013
Hi...there,
It's seems you got a defective DVI card. Try using a VGA cable instead. Have nice day!
ViewSonic VX924... | Answered on Nov 13, 2011
You need VGA cable (Male to Male)
See them here:
http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10201&gclid=CPWQmvXnm6sCFcgZQgodL1AikA
ViewSonic VX924... | Answered on Sep 14, 2011
It is telling you that it wants you to set your PC video resolution to the monitor native resolution of 1920x1200 @60 hz.
You may be able to turn off the resolution notification in the on screen setup menu.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series
ViewSonic VX924... | Answered on Aug 13, 2011
When the DC filter caps no longer filter out high frequency AC, that AC will be fed through out the circuits and cause damages such as the inverter frequency will be running at the wrong frequency and caused overheating.
The service manual does not show the sch of the power supply/inverter board because it is not designed by Viewsonic.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX924/
ViewSonic VX924... | Answered on Mar 27, 2011
It does the same on another PC?
You may have bad LCD PANEL, you can try reseating the cable on the LCD panel first.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
ViewSonic VX924... | Answered on Feb 27, 2011
Look for bad caps as shown in my pictures here: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX924/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
ViewSonic VX924... | Answered on Feb 16, 2011
What is it not doing?
bad caps? http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX924/
I have service manual, 5MB download, send me e-mail, budmrtn@aol.com
ViewSonic VX924... | Answered on Feb 06, 2011
ViewSonic VX924 19" LCD Monitor Logo
127 questions posted
Top ViewSonic Computers & Internet Experts
Ekse
Alun Cox
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ViewSonic Computers & Internet
Most Popular Question
viewsonic vx924 monitor smps failed
  • Computers & Internet
