20 Most Recent
Roland Spd-S Sampling Percussion Pad System Questions & Answers
Roland spd 20 analog test error+reason
The adaptor for the SPD-20 is not 12 V ac (Altern Current) the SPD-20 need only Altern current (12V AC)if the adaptor is 12 v cc, the internal circuits can not made +5v , 0, -5vfor simetrical operactional supply.And Spd 20 show "Analog test err" and "batery low"
Convert ".SPD" to ".WAV"-files ??
There is a lot of software on-line (some free) that can convert the most common files to whatever format you want.
However WAV files are rather large, also it's difficult to put extra information on them, such as album images. It would be much easier to convert the files to MP3.
Roland Spd-s pads not working
Check for a cracked PCB internally from the two defective pads, or if the wires have detached from the trigger. You may not need parts, but if you do, it really depends on how helpful the Roland distributor in your area is as to whether you will have any luck getting them, or you may have to go trough a local authorized repair shop.
Good luck.
Pad sound not geting
the trigger may have gone bad - I'm actually on line now looking for replacement parts.
open up the unit and that part looks like a coin, attached to a wire.
