20 Most Recent Compaq TFT5015 15" LCD Monitor Questions & Answers
4answers
Dim monitor issu. I want it bright always.
it could be age-related but there is also a power setting in the OS. Alternately you can check also the monitor OSD and see if there is a setting for adaptive brightness enabled
1/8/2018 3:55:14 PM • Compaq TFT5015... • Answered on Jan 08, 2018
Out of range
NO PC stated nor OS is it windows what or linux what or O/S2? 10meter . is way too long. sorry. never do that .... 10m means that. why say 10m? lead = cable. VGA cable. it is. VGA will not run 10meters ever, and look ok, (i do know how) out of range means the PC is using ******* resolutions settings on this old monitor. see list of legal resolutions below. the answer is simple.. (NOT REALLY WITH NO PC OR OS STATED) in your unstated PC and OS (windows) we do what, (im blind cant see what you own) if HP PC is get the correct driver from my PC, (GPU/VGA) then it works. if this pc is over 10 years old (last year made not first) then there is no HP support. if running XP or Vista, then Plug in play is not going to work on the dead. (MS shut this down) so i run my scan program (pci dev maker scanner) omg i see the video chip now, and its a XXXX (geforce 123) i got to nVidia and get it and it loads and works (ask how) then in the nvidia driver i set the default resolution to any of the BOLD max resolution's. NO OTHERS ARE ALLOWED BUT THE BELOW OR IS OUT OF RANGE! learn to that using a new PC using and old model the New PC with NEW OS does not recognize this old model its too old. now. so we must force it, in WINDOWs. you must force your unstated video chop to the below resolutions ranges. pick one and set it. there. if running XP or Vista ,both are dead do PNP plug and play is dead, now. in most cases F8 safe boot , set it to say 1024x768 works then you reboot and it stays there. but not if the driver for you VGA chip is missing or wrong. means get it and load it now. in safe mode F8 is this pc connected to the internet as it must? 832 x 624 / 75 Hz 640 x 480 / 75 Hz 640 x 480 / 73 Hz 640 x 480 / 60 Hz 800 x 600 / 75 Hz 800 x 600 / 72 Hz 800 x 600 / 60 Hz 800 x 600 / 56 Hz 1024 x 768 / 75 Hz 1024 x 768 / 70 Hz 1024 x 768 / 60 Hz 1024 x 768 / 85 Hz 640 x 350 / 70 Hz 720 x 400 / 70 Hz
8/2/2017 12:42:40 PM • Compaq TFT5015... • Answered on Aug 02, 2017
Going sleep
Problem on motherboard
7/19/2014 4:06:25 PM • Compaq TFT5015... • Answered on Jul 19, 2014
TFT5015 15" LCD Monitor Results for "Going sleep"
Problem on motherboard need replace it
7/19/2014 4:01:01 PM • Compaq TFT5015... • Answered on Jul 19, 2014
Blank screen when the cpu
Try connecting a different monitor to your computer to determine if the video card or monitor is faulty.
If the monitor is faulty then you could have a faulty inverter board or a CCFL lamp that provides the back light.
Replacement inverter board and CCFL lamps for LCD monitors are available from this WEB site.
www.lcdparts.net
7/14/2011 12:12:14 PM • Compaq TFT5015... • Answered on Jul 14, 2011
Screen break, replace with new tft screen
replace ...
3/5/2010 8:28:04 AM • Compaq TFT5015... • Answered on Mar 05, 2010
Monitor stuck in sleep mode
It will do this when it's not getting a video signal from the computer. Make sure that the signal cable is firmly plugged in at both ends. Also verify that the computer is actually starting up. The monitor may not be getting a signal because the computer isn't sending any.
11/15/2009 10:05:51 PM • Compaq TFT5015... • Answered on Nov 15, 2009
Monitor TFT 5015 now says "going to sleep
Make sure the laptop's external VGA port is turned on. There will be a function key somewhere on the keyboard (location varies by manufacturer and model) that controls the connector. If the connector has gotten turned off the external monitor will go to sleep because it's not getting any input.
4/17/2009 12:43:56 PM • Compaq TFT5015... • Answered on Apr 17, 2009
Monitor: Compaq TFT5015 Displays vertical lines
Check that the signal cable from the computer is firmly connected and that there are no bent pins in either end. If the trouble continues, the problem is in the monitor itself. Given the low replacement cost, it's uneconomical to try repairing these.
4/17/2009 12:40:31 PM • Compaq TFT5015... • Answered on Apr 17, 2009
No backlight
You may have a bad regulator or a bad mercury bulb. Testing either requires a professional with the right equipment. This area contains high frequency current. The mercury bulb is extremely delicate and has to be disposed of properly. I would suggest taking this to a pro.
3/25/2009 7:55:35 PM • Compaq TFT5015... • Answered on Mar 25, 2009
Speakers compaq tft5015
There are no speakers in my Compaq TFT5015 model No PE1212
Are there really any in yours??
3/24/2009 6:47:48 PM • Compaq TFT5015... • Answered on Mar 24, 2009
How to stretch screen compaq tft5015
Right click the desktop - select graphic properties - you should have the option to stretch to fit or something like that. This could also be that your resolution doesnt match your monitor. usual wide screen monitor defaults are 1280/1024 or 1400/1068.. have a mess around and alter these - see which one fits.
1/25/2009 1:01:36 PM • Compaq TFT5015... • Answered on Jan 25, 2009
Sleep mode
There is an On Display Menu (ODM). You can access it by pushing the button located on the monitor. Use +- buttons to navigate in the menu. Here you can switch off the sleep mode or change the sleep settings. I have a simular problem... I try to turn off the power save function but it seems like it dosen´t want to understand this...
10/17/2008 2:34:52 PM • Compaq TFT5015... • Answered on Oct 17, 2008
Compaq presario desktop SR1000 wiring diagram
You can download upgrading and servicing guide from COMPAQ PRESARIO SR1000 - DESKTOP PC MANUAL Pdf Download ' ManualsLib
4/20/2024 1:56:10 PM • Compaq Computers... • Answered 32 minutes ago
Compaq evo n115 boot from usb
Is is probably too old to take Win 10. Also, USB support normally starts once Windows is loaded. During Boot up, it looking for a hard drive or Bootable CD Media. By default, the notebook can start only from a bootable hard drive or bootable drive medium in the notebook. https://www.google.com/search?q=Compaq+evo+n115+boot+from+usb It is 21 years old!!
QuickSpecs
NTS Computers Technology BV https://www.nts.nl > pdf > Compaq_EVO_N115 Compaq Evo Notebook N115. DA-11059. World Wide - Version 7 - August 12, 2002. 1. Overview. What's New. • AMD Athlon™ 4 and Duron™ processors with PowerNow ... 15 pages..
4/18/2024 10:43:22 PM • Compaq Computers... • Answered Yesterday
Where can I find the latest BIOS and drivers for a Compaq Evo N610c laptop
It is 22 years old and there is not support for the virus magnet that is called Windows XP!
COMPAQ N610C QUICKSPECS Pdf Download ' ManualsLib
ManualsLib https://www.manualslib.com > manual > Compaq-N610c View and Download Compaq N610c quickspecs online. Compaq OWNERS MANUAL Notebook N610c. N610c laptop pdf manual download. Also for: Evo n610c. Drivers https://www.google.com/search?q=compaq+evo+n610c+laptop+drivers+download 'Latest' BIOS Upgrade is 2004 (2 year support) https://www.google.com/search?q=compaq+evo+n610c+laptop+bios+upgrade+download https://www.google.com/search?q=compaq+evo+n610c+laptop+bios+upgrade ..
4/18/2024 2:40:38 PM • Compaq Computers... • Answered Yesterday
WifI, I forgot the Password on Compaq F700. How can we reboot and change password, F11 will not work.
From the Service manual https://www.manualslib.com/manual/71736/Hp-Compaq-Presario-F700.html?page=43#manual Unknown user password If the computer you are servicing has an unknown user password, follow these steps to clear the password: NOTE: These steps also clear CMOS. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn the 1. computer on, and then shut it down through the operating system. Disconnect all external devices connected to the computer. 2. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and 3. then unplugging the AC adapter from the computer. Remove the battery (see Battery on page 37) 4. Remove the real-time clock (RTC) battery (see RTC battery on page 44) 5. Wait approximately 5 minutes. 6. Replace the RTC battery and reassemble the computer. 7. Connect AC power to the computer. Do not reinsert any batteries at this time. 8. Turn on the computer. 9. All passwords and all CMOS settings have been cleared. Videos as well https://www.google.com/search?q=Compaq+F700+reset+admin+password ..
4/18/2024 2:37:42 PM • Compaq Computers... • Answered Yesterday
2answers
My compaq 610 windows logo is stuck during booting and even if I want to format it. Any help?
Windows 7 should be the OS. If you go to safe mode, it should complete booting and then you can list the errors but I suspect there is a driver error. Maybe the wrong version in there.
4/17/2024 1:03:41 AM • Compaq Computers... • Answered 3 days ago
Compaq TFT5015 15" LCD Monitor Logo
21 questions posted
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Compaq Computers & Internet
Most Popular Question
monitor compaq tft5015 displays
  • Computers & Internet
