20 Most Recent
Panasonic AG-DP800H Camcorder Questions & Answers
Buongiorno.la macchina in questione
ciao!per difetto di linea di panasonic ag dp800,ho avuto steso problemo,100% sono tre filtri di condensatore elektrolitici,nella scheda video 3700[c 03/c06/c09] e sicuro dopo sostituire tutto ok,o provato io alcuni giorni fa.piu meglio e per sostituire tutti condensatori delle schede video.piu info nell mio email[
[email protected]]
5/17/2011 6:09:10 PM •
Panasonic...
Answered
on May 17, 2011
Lines are coming up on the screen, but we have
Sorry cant fix this for you, but can give you some info....!
I have the same camera, and must say i love it.
But the problems you are having (and myself) since last may are due to a capacitor fault, somewhere inside.
Parts are cheap to replace (about £0.20) per blown capacitor... The cost comes from the labour charged for finding these tricky little devils!
10/30/2010 5:14:04 PM •
Panasonic...
Answered
on Oct 30, 2010
Lines in AG-dp800h
Hello all!!
I found the solution!!
3 electro chemical capacity in the 3700 series on the camera head board.
change the chemical rear the DAC and above the ADC for process digital signal.
The name of the capacity: c3 c6 c9 in the 3700 section on process board.
The capacity is a part of filter the reference signal out of the DAC for ADC reference for ic1 ic2 ic3...
If the capacity is dead a sinusoidal signal appear for the red blue and green reference voltage and the result is a parasit signal into all camera.
You can measure a 50khz signal on the composite video signal.
Best regards
Phil_F
10/20/2009 2:13:27 PM •
Panasonic...
Answered
on Oct 20, 2009
Problem Supercam AG-Dp 800heg
Hello
Situ,
If you must Change the erasing head's supply filter (capaciter) then change the audio erasing Bios OSC, transformer supply filter tantlem capaciter, the problem will be clear.
Regards,
Muthu.M
[email protected]
9/19/2009 7:06:20 PM •
Panasonic...
Answered
on Sep 19, 2009
Where can I download an XP driver for my Panasonic PV-SD5000 camera?
Look for the driver compatible with XP at these sites. You can download the driver for your Panasonic PV-SD5000 camera from the following sources:
Internet Archive: You can download the driver files for the Panasonic Palmcam PV-SD5000 camera from the Internet Archive website . The files are available for free download and include drivers for Windows XP.
Solvusoft: You can download the latest drivers for your Panasonic SuperDisk PalmCam PV-SD5000 camera from the Solvusoft website. The drivers are updated daily and are certified by Microsoft.
HelpDrivers: You can download the driver for your Panasonic PV-SD5000 camera from the HelpDrivers website. The website provides a step-by-step guide on how to download and install the driver.
It is important to download the correct driver for your camera and operating system to ensure proper functionality.
Manual Panasonic PV-L4530
Here it is and it is also available on the manufacturers web site.
https://www.manualslib.com/products/Panasonic-Pvl453d-Vhs-C-Camcorder-2785065.html
