20 Most Recent Hotpoint NBXR463EBWW Electric Dryer Questions & Answers
the part number for the motot is WE17X10010 and runs about $100 and if you need the repair manual that part number is WX10X116 and cost around $25
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Hotpoint... | Answered on Jul 23, 2015
1996 or 2008. GE (hotpoint) uses revolving letter codes for year.
Hotpoint... | Answered on Jan 13, 2014
You have to pull the back off the dryer.Then you,ll be able to see how it comes off.Ussally its on two pulleys similar to a car.There may be a tensioner on it to to keep it from slipping.If there is one you,ll have to losen it to remove the belt & replace it,then tighten the tensioner back up.Ussally you keep about a 1/4" to 1/2" free play on the belt.You use a sraight edge on the two pulleys to measure it with the belt on,tighten belt tensioner till you have the recommended tighteness.
Hotpoint... | Answered on Nov 28, 2013
Where is the fuse located? There are several in a dryer.
Hotpoint... | Answered on Jul 24, 2013
You must get the drum out to inspect the heater element as shown above. After unplugging the dryer open door and remove screws under top of doorframe. As seen in this short video
MORE HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Hotpoint... | Answered on Dec 10, 2012
if the fuse is the right load for this dryer but keeps blowing then there is a sever fault in the dryer this could be in the wiring loom or more likely in the motor the dryer is pulling far to many amps and the fuse should then blow to protect the house wiring from catching "fire!"
yes i did say "fire!" so dont try up-rateing the fuse,,,,thats asking for it!
i would not use this dryer till you have it looked at,,,you will be risking a dryer or house fire if you do,,,
Hotpoint... | Answered on Nov 28, 2012
You need new bearings. Or you can open the machine up and use WD40. You'll need vice grips and sockets for this job.
Hotpoint... | Answered on Feb 15, 2012
Hi
While sliding the old belt off of the drum and pulleys loop one end of the new belt around the drum. Adjust the belt so it fits into the middle of the belt groove.Now Position the other end of the belt around the motor pulley. Pull the idler pulley toward you. Position the belt along the groove of the idler pulley. Release the idler pulley to make the belt tight.
Please check the bellow instruction for more details.
First unplug the electrical cord before replacing the dryer belt.Pull open the dryer door and locate the screws underneath the top lip that secure the top of the dryer.
Unfasten the screws holding the top on with a screwdriver and lift the top, flipping it back and resting it on the hinges.Unfasten the holding the front panel on the cabinet, using a screwdriver. These screws are at the top on the inside of the panel.Disconnect the door switch wires on the back of the front panel by hand, pulling the connector straight out off the electrical prongs and setting the front panel aside.
Locate the idler arm pulley next to the motor on the bottom of the cabinet near the back and push the idler arm forward to relieve the tension on the old belt.Remove the old belt from around the idler and motor pulleys as well as from around the dryer drum and take the belt out of the dryer cabinet.Place the new dryer belt around the drum in the center of the cabinet, fitting the belt inside the V-groove in the center of the drum, and lay the rest of the belt on the bottom of the cabinet near the idler pulley so you can access it easily.
Move the idler arm forward to allow room for the belt and thread the end of the new belt around the idler arm pulley and over the motor pulley, letting the idler arm move back to apply tension to the new belt. Check the new belt over to verify that it is lined up correctly in the V-groove on the drum and around the pulleys and that there are no twists in the belt.
Place the front panel back on the dryer cabinet, securing it with the screws on the top of the panel with a screwdriver, and plug the door switch wires back into the electrical prongs, pressing the switch wires on by hand on the back of the front panel.Lower the top of the dryer back down onto the cabinet and secure it with the screws underneath the lip of the front panel.
Plug the electrical cord of the Hotpoint dryer into the electrical outlet.
Also check this bellow links to have an in-depth knowledge related to your issue:-
http://www.ehow.com/how_5189091_replace-belt-electric-hotpoint-dryer.html
http://www.ehow.com/how_7357167_install-hotpoint-dryer-belt.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Hotpoint... | Answered on Mar 29, 2011
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Hotpoint... | Answered on Mar 04, 2011
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Hotpoint... | Answered on Feb 02, 2011
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Hotpoint... | Answered on Jan 03, 2011
Check the bias thermostat on the blower wheel housing, thermal fuse, high limit thermostat, and heating element on the back of the machine for continuity with a multimeter. Replace any of the mentioned parts with new one form the parts list below. Below is a video to show you how to check for continuity. The dryer is a little different, but the principles are the same.
Bias Thermostat Thermal Fuse High Limit Thermostat Heating Element
Hotpoint... | Answered on Dec 30, 2010
Dryer Repair - The
Dryer Repair - The
heatman101
Hotpoint... | Answered on Dec 17, 2010
Remove the electrical panel with the timer,start switch,etc from the machine by removing the screws that hold it to the top of the machine.
Remove the lint filter, and the two screws that attach the housing to the top of the machine.
Most of the time you would use a screw driver at the corners of the lid to pry between the lid and the top of the body of the machine and it is held on by clips...but sometimes the lid will also slide to be removed.
Free answer...Please rate me
Hotpoint... | Answered on Dec 09, 2010
Pull the idler over the top of the motor and loop the belt on it like this themobilian_293.jpg
I have a complete pictorial HERE
Hotpoint... | Answered on Nov 28, 2010
Hairspray is an excellent solution to the ballpoint pen ink problem. Buy the cheapest you can find and spray, let the spray sit on the spots for a few seconds and wipe with a paper towel. Keep doing this until the spot is removed. This also works on fabrics as well. As a former teacher, my red grading pen ruined several of my white shirts. I used my husband's $1.29 can of hairspray and saved over $100 in garments. He was pretty angry about my using all his hairspray but when I pointed out the money saved by not having to purchase new blouses, he relented. I keep a can of hairspray in my laundry room at all times.
Hotpoint... | Answered on Nov 04, 2010
Hotpoint NBXR463EBWW Electric Dryer Logo
Popular Tags
87 questions posted
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
peter gittos
peter gittos
jimorris77
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
View Most Popular
Hotpoint Dryers
  • Hotpoint Dryers
Most Popular Question
motor in dlb6850balwh dryer
  • Dryers
