20 Most Recent
HP Pavilion F1503 15" LCD Flat Panel Monitor Questions & Answers
HP Pavilion F1503 LCD Monitor
If you can see the backlight ,white 2pin connectors connect to invertor pCB.Look around these two connectors you should see 2 brown/yellow/red transformers with a ferrite core.These are the inverter transformers , resolder all pins and power transistors around it.
That should solve your proble.
Please provide feedback and rate this solution.
Samir.
Panel blue light blinking
Make sure the monitor is connected to the box (desktop) and that box or desktop is turned on.
Make sure the cable is good.
Make sure the input on the monitor is on the right input (example, VGA, HDMI, DVI). Should be a button to switch between those options
A blue box pops up on my screen and I can't get rid of it
i can't see the box, why not post photo, be like 2nd ever to do that here.
the menu button unlocks per the manual,
push said LCD menu button for 10seconds and it unlocks.
the lock is to keep kids from messing up your LCD controls
if you see sleep timing in the LCD turn that off, or pain happens.
the LCD OSD menu is called that OSD, on screen display.
lost the manuaL>?
is the unstated PC turned on, if not the LCD will complain.
NO signal, no sync, out of range, etc.
RTM?
its all there. free, posted here vast times.
https://www.manualslib.com/manual/71406/Hp-Pavilion-F1503.html
HP vs17e automatic auto-adjusts randomally.
well why not try the monitor on any other computer
if it fails there,
bingo bad monitor.
easy no?
that shifting is bad. real bad,
if the problem in only on your PC.
then the Video (card or GPU chip) is bad.
you never said what you are plugged into
1981 to 2017, 10,00000 systems. made.
HP Pavilion F1503 only displays a split second?
well, its a 2003 LDC 13 years old ,
its bad
the monitor itself of the power pack to it is bad.
you can test it on any PC< or laptop made
if its dead on all , then its dead.
what more needs saying,
older LCD monitors had old CCFL, lamps. that love to fail
newer are LED back lights that last for ever. it seems
so up grade?
seems your back light is dead
ever do the flash light trick
shine it at the dead screen see good data
yes, then the CCFL is DEAD< (or its power supply ,deep inside)
fixed may but would never do a 2003, not now.
lots of used good LED for sale,
What could be wrong with HP Pavilion f1503 screen?
This is usually faulty capacitors. They are in charge of regulating the power of your monitor, with time, they will go bad. The replacements of this capacitors is usually under $10 or $15 usd.
You will need to open the screen, identify, unsolder and buy the new ones to later on solder back and BOILA!
Power on but image on screen is very faint. What could the problem be?
HP monitors are renowned for having the inverters quit working. To repair the inverter you disconnect the power and if a laptop also remove the battery. Remove the plastic bezel (edge plastic around the screen), this can be done by lightly prying the plastic away from the screen, at the bottom of the screen just behind this plastic bezel you will see a small printed circuit board with 1 or 2 screws holding it in place with wires plugged into it, you will need an exact replacement part, the part numbers are printed on the board. Most boards are readily available for around $20 or less on Ebay. Carefully unplug the wires and screws, install the new board, attach wires, replace screw(s), snap bezel back in place making sure no wires get pinched, and you should be good to go. 30 minute fix for a novice.
I want main menu off my screen
If you are referring to the monitor's setup menu, the buttons on the front panel will provide a cancel or end of fuction controls. If it is a Windows menu, you are stepping into a forbidden zone. Windows 8 took away most menus that most people complained of losing. Windows 8.1 gave it back to them.
-DellTech1
Which model of Inverter Board does HP pavilion f1503 uses?
The part is a "ribbon cable" for an lcd monitor...ribbon
made by Youngshin (AWM 2896 30V 80C VW-1). 2 ribbon cables for a hp
pavilion f1503 LCD monitor (the two from the AD board to the TCP)The
LCD panel is made by HannStar (HSD150SX84). Also, looking for other LCD
parts, particularly: the AD board for a Proview Pro-576 (I assume Sylvania
PL-576 & Mag LT576s are similar); Board #: 200-100-AS576 Rev: B MV5-S2?
It uses a sampo inverter (QPWBGL8621DG) & a AU Optronics M150XN05 LCD.
HP LP2065 MONITOR goes to sleep
Hi There
The Monitor setting you set through the computer, may you select the sleep mode or hibernate. Chang the mode and fix the problem. Thanks http://pacificbits.ucoz.com/
Osd lockout
hold the MENU button for ten seconds to unlock or lock the OSD
