though itz very unclear n i don't understand the moral meaning of windows going down..!!..n wat is the link of windows going down with ur monitor..
however, itz probably causing from faulty or defective smps or main/mother board..
if not probably itz causing from the monitor itself..
proceed to verify with the below stated steps, only if u r a professional..
DO IT ONLY IF U R A PROFESSIONAL..
..plz do check the following as in order:..
the Hardware part:..
1) check mains/power supply..the fuse, switch, wiring n associated circuitry..
2) [in case of desktop] the
smps itself may b defective/faulty..check the outputs of smps viz. 0v(black~ground); +12v(yellow); +5v (red, green~ps-on, violet~pg&grey~sb); -12v (blue);-5v(white); +3.3v(orange)..
check the battery
n adapter [main power], in case of laptops..replace with a standby n see..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
4) open the cpu n see if heat is generated..if not..replace the cpu n see..
5) open the CPU Heat-Sink with fan out of thesocket..put some "Heat Sink Compound" (available in local electronicschip level spare market)between the cpu/processor and the CPU Heat Sink*** fan..resit/fit it tightly in position..
6) on
main/motherboard..see with a debug card for mb error..may b short..look fordefective capacitors(espabove1000mfd)/mosfets..go through the mb'ssouth bridge n the circuit lie around atx connector..the crystal clockgenerator (if cpu isn't heating up)..
7)seeif the ram(s) is loose/faulty..open clean/remove carbon & or oxideformed on the teeth with an eraser n resit it..or replace with a standbyn see..
8)remove/clean dustneatly..dust is non-uniform in nature n may causejam/short circuitry/excess resistance n many more..resulting an increasein heat..
9) if all above fails..just try to service the monitor..open and re-sould all the dry soulderings..itz probably is causing due to ur monitor's internal circuit dry-soulds..esp. at the crt base n around the horizontal output section (hot)..
the Software part:..1)hv a licensed and UPDATEDantivirus installed (i prefer avg/kaspersky,remember, without updationa full version antivirus is useless)..
2) download, install n run microsoft kb890830..
http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
3) download n run Startup Control Panel..
http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'removeall the unnecessary startup items from here..(if u can't find whatto remove, post me/us in ur comment with all the items listed in eachn every tabs herein)..
4) remove all unnecessary software from add/remove programs..
5) download, install n run 'Advanced System Care Pro'..
http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
6)disable the following:..
a)'Automatically Restart'right click on my computer->properties->advanced->startupn recovery->(un check on the) Automatically Restart;
b)'Error Reporting'right click onmy computer->properties->advanced->error reporting->disableerror reporting->(uncheck on the) 'but notify me when critical erroroccur'..
7) Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
if u r not a professional, always better to seek advise from ur system admin/vendor....
