20 Most Recent Hotpoint Aquarius WMA42 Front Load Washer Questions & Answers
This sounds like the thermostats
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Hotpoint... | Answered on Sep 27, 2018
I would check the water pump for a blockage a button or other debris may be lodged in there preventing it for operating properly eric
Hotpoint... | Answered on Jan 17, 2018
Yes then check the motor carbons
Hotpoint... | Answered on Jan 10, 2018
maybe the concrete balancing weight has come loose and the fact that most of the water has been drained off when you turn it off for 10 seconds it does not have the one-sided affect anymore also check the damping springs as one may have come off in the violent spin eric
Hotpoint... | Answered on Dec 27, 2017
Call warranty service as trying to fix yourself may void warranty
Hotpoint... | Answered on Nov 12, 2017
Hello!
Please check the Troubleshooting part of the manual. https://manualsbrain.com/en/manuals/1861489/?page=18
Hope it will help
Hotpoint... | Answered on Aug 09, 2017
It might be grease from the bearings due to a failed seal.
Hotpoint... | Answered on Jun 26, 2017
sounds like possibly a sloppy bearing causing the drum to wobble excessively nothing can be done to avoid this other than change the bearing. always assuming your load isn't seriously out of balance of course.
Hotpoint... | Answered on Sep 04, 2016
push on the door where the lock is... it may not be fully locked.
Hotpoint... | Answered on Aug 02, 2016
My washing machine runs for 10 minutes then all the lights start flashing also there's water in the drum, I've drain the water twice but it does the same thing.
Any idea what's going on there pls.
Hotpoint... | Answered on Mar 24, 2016
Hi Margaret
I'm having trouble finding the model or brand numberrs you've provided. If you look here
http://www.appliancepartspros.com/ge-washer-handle.html
you can see a selection of GE washer handles and their part numbers.It's selected for General Electric for vendor since GE manufactures
Hotpoint
Good Luck!
D
Hotpoint... | Answered on Nov 24, 2015
Washing machine working fine conditioner being used but water always left in draw washing machine is cold fill only This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Hotpoint... | Answered on Oct 02, 2015
check pump for a blockage....
cheers
Hotpoint... | Answered on Mar 10, 2015
The WMF540 motor is usually quite robust, depending on the symtoms.... I would look at the Main control panel, and check the brushes on the motor.
Hotpoint... | Answered on Feb 12, 2015
check ur door switch , belt, clutch or motor coupler/
Hotpoint... | Answered on Feb 11, 2015
It's probably just caked with powder or conditioner and needs cleaned. Your handbook gives instructions on how to remove the drawer. Alternatively the dispenser to drum inlet hose may be blocked and some hot water may clear that.
Hotpoint... | Answered on Jul 14, 2014
Hotpoint Aquarius WMA42 Front Load Washer Logo
669 questions posted
Top Hotpoint Washing Machines Experts
Eric Taylor
James Hehling
James Hehling
Level 1 Expert
Onofrio Taverna
Onofrio Taverna
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Washing Machines
Most Popular Question
cannot read intructions hotpoint
  • Washing Machines
