20 Most Recent RCA 7in twin screen portable Questions & Answers
My son locked the tablet and dont know the password
You need to do a factory reset, follow these instructions: Step 1. With your tablet turned off, press and hold the volume up (+) button. While holding the volume up (+) button, press the tablet's power button until you see the RCA logo with Nipper and Chipper on the screen. After a few seconds, the screen will change and you will see the Android bot on his back with a caution symbol above him. Step 2. Now you are going to press and hold the tablet's power button, and without releasing the power button press down on the volume up (+) button. You should then see the screen below. Step 3. Use the tablet's volume up (+) and down (+) keys to navigate to and select the "wipe data/factory reset" option. To select this option, press the power button. Step 4. The tablet is going to ask you to confirm your selection. Use the tablet's volume up (+) and down (-) keys to navigate to and select "Yes - delete all user data." Once again, use the power button to select this option. Step 5. At the bottom of the next screen, you will see "Data wipe complete." Press the power button to restart the system.
1/3/2015 5:37:25 PM • RCA 7in twin... • Answered on Jan 03, 2015
Can my speakers with wire be hooked to my RCA black screen?
If it is an RCA television and has a black screen, you need a new one. They are low quality and not worth repairing. https://www.google.com/search?q=RCA+black+screen ..
2/6/2024 6:20:23 AM • RCA Car Audio &... • Answered on Feb 06, 2024
Rock ola 55015-1A Amplifier add bluetooth
Adding Bluetooth functionality to a Rock-Ola 55015-1A Amplifier involves a few steps and considerations to ensure compatibility and proper functionality. Here's a general guide on how to add Bluetooth to your Rock-Ola 55015-1A Amplifier: 1. Gather the Necessary Equipment:
  • Bluetooth audio receiver module
  • Wiring tools (soldering iron, wire strippers, solder)
  • Audio cables (3.5mm or RCA)
  • Power supply (if required for the Bluetooth module)
9/1/2023 6:53:26 AM • RCA Car Audio &... • Answered on Sep 01, 2023
Diagram for DEH -56HD color chart for wires
The installation wiring diagram is shown on page 13 of the manual, available at https://www.pioneerelectronics.com/PUSA/Unassigned-Content/Manuals/DEH-X5600HD+OWNERS+MANUAL . The w/r port is for a hard-wired remote control that was sold separately. RCA cables are used with the DEH-X56HD to connect a power amplifier to a sub-woofer or rear speakers. See pages 12 (for setting the unit correctly) and 14 (for the wiring diagram). I hope this helps. Cindy Wells
1/12/2023 2:55:54 AM • RCA Car Audio &... • Answered on Jan 12, 2023
"My marantz avp 8802a sub out 1 not working properly ones remove rca cable and fit back then sub work ?
can you elaborate all that, no sub maker/brand model told) tell it all what works and does not work both. ones =once? well it has 2 jacks sub1 and sub2. so swap them if the problem fails on moved sub the sub is bad. if the new moved sub fails on same channel the channel is bad in the head, or cables are bad. then swap cables. there are 3 fail points here. the main head. out. sub1/2 2 cables RCA SIMPLE COAX , easy to buy cheap and replace. 2 subs. super easy to diagnose any like this 2 subs. (it's redundaNT bliss) my actual sub has power AC and rear volume and on/off on rear of sub speaker, so any of that can be wrong, but not told you what you have, we can not see what you have at hand.
7/4/2022 2:02:20 PM • RCA Car Audio &... • Answered on Jul 04, 2022
RCA RV-9900A How many watts per/each channels??
ask RCA or google
12/29/2021 7:26:11 PM • RCA Car Audio &... • Answered on Dec 29, 2021
2005 Mitsubishi Montero limited edition colors of speaker wires that go into rear amp. Trying to connect a sub and amp. Need to hack the wires for rca hook up
LEFT FRONT==WHT/BLK-NEGATIVE LEFT FRONT==WHT=POSITIVE RIGHT FRONT==GRAY/BLK=NEGATIVE RIGHT FRONT==GRAY=POSITIVE RIGHT REAR==VIOLET/BLK=NEGATIVE RIGHT REAR==VIOLET=POSITISVE LEFT REAR==GREEN/BLK=NEGATIVE LEFT REAR==GREEN=POSITIVE YOU NEED THE CONNECT A HI/LO LEVEL TO THE REAR SPEAKER WIRES TO THE REAR SPEAKER WIRES TO GET SIGNAL TO THE AMP;;
5/13/2019 1:37:27 AM • RCA Car Audio &... • Answered on May 13, 2019
Why does my car audio amplifier power on but has no sound?
This is a sign that the amp is being overtaxed by a subwoofer or other speakers to the point where it simply can't provide enough power. In home audio setups, clipping is typically caused by an underpowered amp or inefficient speakers, but loose or burnt wires can introduce similar problems in cars.
11/2/2017 7:08:17 PM • RCA Car Audio &... • Answered on Nov 02, 2017
2answers
My car sub woofer is humming (I'm pretty sure) when I unplug the rca it goes away but when plugged in has the humming and barely hits all connectiona are good so I'm really baffled its a 4 ch amp that
make sure your rca are not up against any heavy metal or pinched by something. cheap rca cables have no type of insulations coating and when up against metal will cause interference. mine did the same thing when I ran it up against the seat belt bracket... pull it out from where you have it routed from but leave it all hooked up and see if it still MAKING the same noise if it goes away then try reroute or get better rca and make sure no pinched wire hope this helps .... always go with good rca cables
10/28/2017 7:14:22 AM • RCA Car Audio &... • Answered on Oct 28, 2017
2answers
Which rca wires are for sub
White and red
4/9/2017 6:46:54 PM • RCA Car Audio &... • Answered on Apr 09, 2017
I have a kenwoodkdc-mp228 cd changer in my car are the two rca plug ins on the back for the amp input and what button do i push too access the sound for amp
Hmm, even the actual manual is a little confusing, it covers too many models.It suggests if you have 2 sets of RCA's they are OUTPUT ONLY, so you can run external amps and save the units amp chips.The external amps will come on automatically if connected correctly.http://manual.kenwood.com/files/B64-2926-10.pdfFull wiring diagram on page 25 :0D
1/17/2017 4:33:10 AM • RCA Car Audio &... • Answered on Jan 17, 2017
Can i replace the rca jacks on a subwolfer?
Yes. Positive wire to center pin ground to outer ring.
8/17/2016 1:58:19 AM • Car Audio &... • Answered on Aug 17, 2016
I have an rca cd player model RS2928B and my speaker wire that connects to the connector in back of stereo broke off the connector piece. Can I get a replacement connector or what do I do
I think your best chance for a replacement would be a place called Allied Electronics. They have online service. The other option is to change the connector style. Get a new Male and Female of a light duty type and replace it in your unit. You will have to dismantle the player to do this and will require some soldering.
7/3/2016 11:48:20 PM • Car Audio &... • Answered on Jul 03, 2016
0answers
Eclipse avn 5435 deck plays fine but once in a blue moon no sound comes from it. Only using rca on unit, gps works fine. I unplug all connectors and then works fine.
Jess, do a wiggle test on cables when you have volume, wiggle wires one at a time to see if sound goes out or static. press the helpful button
2/7/2016 11:41:53 PM • RCA Car Audio &... • Answered on Feb 07, 2016
Brand new radio not working since i wiggled the rca wires on amp
bring it back if its new
7/12/2015 6:35:04 AM • RCA Car Audio &... • Answered on Jul 12, 2015
RCA 7in twin screen portable Logo
1 questions posted
Top RCA Car Audio & Video Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a RCA Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Car Audio & Video
Most Popular Question
son locked tablet dont know password
  • Car Audio & Video
