20 Most Recent
Motorola Mobility V262 Questions & Answers
How to delete all contacts and call logs before
Here i am going to attach a file actually taken from its user manual that how u can delete the contacts named as (Delete Entry).
If you have its user manual then u can see all details.
And to delete call logs, see this
hope it will help you.
Don't forget to rate it, if it helps you
good luck
1/22/2010 2:03:47 PM •
Motorola...
Answered
on Jan 22, 2010
My v262 won't turn on
have the flexcable replaced or the lcd on the phone take the phone to a mobile tech and have diagnosed it and fix it for you....
8/1/2009 10:12:46 PM •
Motorola...
Answered
on Aug 01, 2009
I have a motorola v262
graydog,
if you manage to change the keypad most probably the condenser MIC inside the phone been misaligned. try to check if the condeser MIC is properly sitted on it's original place and if you do have a multi tester you might as well check the resistance of the condenser MIC.
the nromal resistance for condeser MIC is 500ohms and some are 60 omhs.
cheers
mark
1/17/2009 6:54:52 AM •
Motorola...
Answered
on Jan 17, 2009
Can't figureout how to remove my sim card.
which v262 phone do you have? if it does not say v2622 on the side of the box under the upc. it might have been the model that was recalled.
you should check into that. you might get a new version the the phone which is suposed to be great.
other than that. in some motorola phones you have to push down and slide out.
others you have a little silver sliding lock the you just push to the side.
3/6/2008 3:48:21 PM •
Motorola...
Answered
on Mar 06, 2008
Sound
You need to check the setting if the phone is not put to a sort of mute setting while pressing the buttons.
2/15/2008 4:17:52 AM •
Motorola...
Answered
on Feb 15, 2008
I want to reset my Motorola v262
u can make the security code to default by doing the following....
download the software called p2ktools from net
... and connect your cell to pc it will ask for driver to install then
give the location "drv folder" inside p2k tools.. then just go p2k mode
then give flex ... by flexing your problem may get solved(there will one more option called check for codes from there you can remove codes).....
note: while downloading p2k tools download the old version dont download the new version (new version may be p2k tools3)
2/10/2008 5:06:24 AM •
Motorola...
Answered
on Feb 10, 2008
Display screen
that is wierd - you can try the first solution to have it flashed, but 30% that's the answer, somehow your lcd probably burnt out so a simple replacement is required - it would cost about $30-40 for the lcd and the installation
1/26/2008 2:28:08 PM •
Motorola...
Answered
on Jan 26, 2008
Razor
Yeap it sounds like an stuck down button due to moisture to the keypad or whole phone, the keypad could be repaired or replaced. Any questions please ask.
1/8/2008 10:24:42 AM •
Motorola...
Answered
on Jan 08, 2008
Having trouble turning on
The cell company I have has a device that transfers the number to your new phone. It desn't matter if your old phone is no longer working.
6/10/2007 12:44:07 AM •
Motorola...
Answered
on Jun 10, 2007
