hi there,
You can download ganes to you phone through different methods like: Over-the-Air (OTA), Infrared (IR), Bluetooth and Cable
1. For uploading through OTA: make sure your wap is well configured and working (each operator has different settings). Enter the .jad url of the game (URL of jad can be found below), then the phone will automatically download the .jad file. After the .jad file is downloaded you will be prompted to confirm the downloading of the .jar file. If you press yes then you can download the file and install the game. Volia! In general you should make sure that the .jar file will fit on your phone. Some devices like Nokia Series 40 (MIDP1) limit the .jar size to 64k, others will limit it to under 100k. Also most devices have a low limitation on the size of all games (midlets) installed, so you should always check the available memory and in some cases remove any old unused games. We have taken the limitation of each device into consideration and there's nothing to worry about here.
2. For uploading through Infrared: First you should get an IRDA peripheral and connect it to your PC. It's usually a USB device. Connect it and install the software.
Now there are two cases:
a. either your phone supports IRDA directly and in such case it's sufficient to upload the .jar file to your phone by right clicking on the file and use 'Send to' menu. Note that you should configure IRDA properly to connect to the phone. We are using the following configuration for SigmaTel USB-IRDA: "Infrared Transiver Type": SigmaTel 4000, "Min. Turn-Around Time": 1.0ms, "Speed Enable": 115200.
b. or your phone doesn't support IRDA directly but has IR. In such case you should use your manufactorer software like Nokia PC Suite.
3. For uploading through Bluetooth: Usually this is faster and easier than Infrared. Install your Bluetooth usb device. Right click on the .jar file and select the menu 'bluetooth device' inside 'send to'. You can also pair your device with your computer to make things faster. Once the .jar file is on your phone then you can install it
4. For uploading through cable: some phones don't have neither Infrared nor bluetooth support. You can use the manufactorer cable and connect it your PC (either USB cable or com cable). In such case you should also use a dedicated software for uploading files to your device
Please use the below mentioned link to find games.
http://www.zgroup-mobile.com/demos/Motorola_C650/index.html
thanks,
S.
