20 Most Recent
Samsung SGH-p207 Questions & Answers
Simlock samsung SGH-P207
Using the codes you can unlock your sim lock in your mobile because its safe for your mobile...Get the sim unlock code for your samsung sgh p207 model mobile from this site
Simpleunlocking.com , here it gives the easy methods to get the mobile unlocked........
L want know how can l unlock my mobile phone
You
can
get the unlock code by contacting your current service provider
customer care department. If your phone is locked you can use any of
your friends phone to make this call. The
service
provider will then provide you the unlocking codes. Everything is done for free of cost and you are not going to be charged
for this process.
Another alternative is, you can take the
phone to any authorize phone service center to help unlock the phone,
because to unlock your phone, you will need some kind of software, USB
cable
etc to unlock the phone, so you can also go a nearby phone service
center to unlock the phone,
but calling your network service provider is the best because they have
the records of your phone and can easily help to unlock it. This are the
two reliable means you can unlock your phone.
Hey,hi how do i flash my samsung cellphone
Welcome to fixya
I have a solution for this
Content
Please download the latest update for your phone from samsung.com this process will update your phones firmware, ensure to backup all your information before performing an update for your flash.
More information is available in the comments
My name is Bruce
Samsung (SGH-p207)
I seem to have exactly the same problem.
I don't know if you installed the USB cable driver, and already tried selecting the proper port in the Samsung software.
To determinate if the cable driver is properly installed and which COM port it has asigned, right click on my computer (in your desktop or the start menu), click on properties, go to the hardware tab, click on the device manager button, expand the ports thingy, and look up for USB data cable or something similar from the device list. Find out the COM port then go to the samsung software and select that port from the list in the configuration window. Close and re start the program (or press F3, don't know if it works in all versions of the software)
I really hope it doesn't works, because then it's a problem of the software and not of my own phone!!! Anyway post here your results so I can tell.
Samsung SGH-p207 Vibrating All the time
if you vibrating continuously, it probably needs service, but if you mean it just won't ring instead of vibrating when a call comes in, go to settings in the main menu (usually the "ok" button), then sound settings
Its a nokia 6555 -
need a usb cable suited to the specific phone, plus software--should be anywhere from $20-50 online. search "nokia, download"
SPH-P207 Camera Problems
when it "freezes" it's usually just taken a picture (easy to accidentally press the shutter) and is showing it to you--press save (left function) or erase (right) then is ready for another--can tell because the picture is moving as you move the phone
HELP !
what network are you with ?
How do i transfer pictures from the camera to my computer?
