20 Most Recent Hotpoint Ultima WF860 Front Load Washer Questions & Answers
Just had same problem with my hotpoint wmf740 showing h20 and found an easy fix was to clean out the detergent draw thoroughly and just behind it.to remove tray was easy and it does say to do this regulary in the manual
Hotpoint Ultima... | Answered on Aug 05, 2018
Hi I hope this helps....
Hotpoint Ultima... | Answered on Mar 01, 2018
Common fault best to fit 3 at one time.
Hotpoint Ultima... | Answered on Sep 13, 2017
Probably the PCB has failed . I hate new electronic things . OLD mechanical fail less often
Hotpoint Ultima... | Answered on Sep 07, 2017
The problem may be the water supply. There could be a high sulphur content.
Hotpoint Ultima... | Answered on May 13, 2017
From the manual page 24:
'Door' is flashing in the display window...
?Shut the door firmly, until it clicks.
The symbol should now go out.
I suspect the door sensor has failed. It thinks you haven't closed the door, so it refuses to do anything at all. It's called a Door Interlock, it has a switch or sensor built into it.
First try unplugging the washer for 60 seconds and plugging back in to try to reset the controller. (Dry hands only!)
If the door interlock is a simple switch, you should be able to check it with an ohmmeter. I would check it first before buying a new one.
The part number is HPTC00085194 or C00085194, here are a couple places you can buy one. You can also find them on ebay.
Washing Machine Door Interlockby Indesit
Door Interlock Washing Machine
WASHING MACHINE DOOR INTERLOCK C00085194 design may vary
Hotpoint Ultima... | Answered on Sep 21, 2016
hi, has the seal been replaced?if not use an old tooth brush and clean it with tooth paste it will clean off the mould, if the seal has been replaced check around the rim for a drain holle it may have been fitted wrong, some dont have drain holes hope this helps
Hotpoint Ultima... | Answered on Mar 18, 2016
F05 means that the pressure switch is jammed on full.
You need to check the pump is pumping out o/k, and if there is a filter, check and clean.
Hotpoint Ultima... | Answered on Jan 22, 2016
Hotpoint Ultima WF860 Front Load Washer Logo
1,290 questions posted
Top Hotpoint Washing Machines Experts
Eric Taylor
Richard C Cohen
Richard C Cohen
Onofrio Taverna
Onofrio Taverna
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Washing Machines
Most Popular Question
hotpoint washer wont work
  • Washing Machines
