20 Most Recent Brother MFC 7420 All-In-One Laser Printer Questions & Answers
are you using the autofeeder to feed your documents?
if yes, open the top cover and clean both glasses (big and small).
and take the drum out, move the blue panel to clean up your drum.
after that should be working fine.
Brother MFC 7420... | Answered on Aug 23, 2019
To send a fax, you will have to configure the settings. here are the steps you can follow;
Remote Fax Options;
You can only use one remote fax option at a time:
Fax Forwarding—OR—Paging—OR—Fax Storage—OR—PC FAX Receive—OR—Off.
You can change your selection at any time (Menu/Set, 2, 5, 1).
Setting up Fax Forwarding
When you select Fax Forward, your MFC stores the received fax in the memory. The MFC will then dial the fax number you’ve programmed and forwards the fax message.
  1. Press "Menu/Set, 2, 5, 1".
  2. Press ▲ or ▼ to select "Fax Forward". Press "Menu/Set". The LCD will ask you to enter the fax number to which faxes will be forwarded.
  3. Enter the forwarding number (up to 20 digits). Press "Menu/Set".
  4. Press ▲ or ▼ to select "Backup Print:On or Backup Print:Off". Press "Menu/Set".
If you select "Backup Print:On", the MFC will also print the fax at your MFC so you will have a copy if there is a power failure before it is forwarded.
5. Press "Stop/Exit".
Programming your pager number When Paging is selected, your MFC dials the pager number you’ve
programmed, and then dials your Personal Identification Number (PIN). This activates your pager so you will know that you have a fax
message in the memory.
1. Press Menu/Set, 2, 5, 1.
2. Press ▲ or ▼ to select Paging.
3 . Enter your pager phone number
followed by # # (up to 20 digits). Press Menu/Set.
Do not include the area code if it is the same as that of your MFC. For example, press 1 8 0 0 5 5 5 1 2 3 4 # #.
4. If your pager needs a PIN, enter the PIN, press #, press Redial/Pause, enter your fax number followed by # #. Press Menu/Set. (For example, press 1 2 3 4 5 # Redial/Pause 1 8 0 0 5 5 5
1 2 1 2 # #) —OR— If you do not need a PIN, press Redial/Pause, enter your fax number followed by # #. Press Menu/Set. (For example, press Redial/Pause 1 8 0 0 5 5 5 1 2 1 2 # #)
5. Press Stop/Exit.
■ You cannot change a Paging number or PIN remotely.
■ If you have set Paging, a backup copy of the received fax will
automatically be printed at the MFC.
Setting Fax Storage
If you select Fax Storage, your MFC stores the received fax in the
memory. You will be able to retrieve fax messages from another
location using the Remote Retrieval commands.
1 Press Menu/Set, 2, 5, 1.
2 Press ▲ or ▼ to select
Fax Storage.
Press Menu/Set.
3 Press Stop/Exit.
Setting PC Fax Receive
If you select PC Fax Receive, your MFC will temporarily store your
received fax messages in its memory, and then automatically send
the faxes to the PC. You can then use your PC to view and store
these faxes.
PC Fax Receive.
Press Menu/Set.
3 Press ▲ or ▼ to select
Backup Print:On or
Backup Print:Off.
Press Menu/Set.
4 Press Stop/Exit.
If you have turned on Fax Storage, a backup copy will
  • Before you can set up PC Fax Receive you must install the
MFL-Pro Suite software on your PC, make sure your PC is connected and turned on. (For details, see Using Brother PC-FAX software on page 5-1 in Software User’s Guide on
the CD-ROM.)
  • If you select Backup Print:On, the MFC will also print the fax at your MFC so you will have a copy if there is a power failure before it is sent to the PC.
■ If you get an error message and the MFC cannot print the faxes in memory, you can use this setting to transfer your faxes to your PC.
Turning off Remote Fax Options If you set the Remote Fax Options to Off and there are faxes in your MFC’s memory, the LCD will give you two options.
  • If you press 1, all unprinted faxes will be printed and erased
before the setting turns off. If a backup copy has already been
printed it will not be printed again.
  • If you press 2, the memory will not be erased and the setting will be unchanged.
Setting your Remote Access Code
The remote access code lets you access the Remote Retrieval features when you are away from your MFC. Before you use the remote access and retrieval features, you have to set up your own code. The default code is inactive code (--- ).
  1. Press Menu/Set, 2, 5, 2.
  2. Enter a three-digit code using numbers 0-9 or . Press Menu/Set. (The preset ‘ ’ cannot be changed.)
  3. Press Stop/Exit. Do not use the same code which is set in your Fax Receive Code ( 51) or Telephone Answer Code (#51). You can change your code at any time by entering a new one.
  4. If you want to make your code inactive, press Stop/Exit in Step 2 to restore the inactive setting (--- *).
Brother MFC 7420... | Answered on Jun 04, 2019
E52 Laser Motor Unit Fault.
Brother MFC 7420... | Answered on May 07, 2019
Sorting copies using the ADF
You can sort multiple copies. Pages will be
stacked in the order (1, 2, 3), (1, 2, 3)
and so on.
1 Press (Copy) to illuminate it in
green.
2 Load your document.
3 Use the dial pad to enter the number of
copies you want (up to 99).
4 Press Options and ? or ? to select
Stack/Sort.
Press Menu/Set.
5 Press ? or ? to select Sort.
Press Menu/Set.
6 Press Start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Brother MFC 7420... | Answered on Mar 25, 2019
I had this problem when tried to install network driver to Brother HL-L2340D (exactly InstallNetworkDriver - 3, not InstallNetworkDriver - 1). Tried it several timers, when print spooler service was running. But still got the same error.
Finally, i forgot about install wizard and installed driver manually (for my Win2008R2x64, it was DeviceManager >> Install old device >> Manual choice from list >> Show all devices >> Install from disc >> target to unzipped wizard content folder (...install/driver/gdi/32_64) >> select wanted printer model in appeared list >> continue install it.
After that, you can install this printer with standart applets of control panel (Printers > Install printer), it successfully finds printer in network and add it to list.
So, i still don`t know the reason, but have the solution.
Brother MFC 7420... | Answered on Oct 11, 2018
Is it giving any errors when you try to print?
Brother MFC 7420... | Answered on Sep 22, 2017
At least it is sorted now. They can be troublesome at times.
Brother MFC 7420... | Answered on Aug 22, 2017
all brother printers and mfc products. if you are using generic tonere or refills, brother products will not recognize the toner cartridge as the refillers do not know how to reset the toner cart. this is priority info. therefor u must use brother oem toner.brother service rep
Brother MFC 7420... | Answered on Jun 05, 2017
I would guess it is the rollers. You can try to replace them. You can order them online. To find out what type you need, look on the back of the printer for the make and model.
Elisa Jed ' http://www.blinds2go.com.au/blind-parts/roller-blind-parts/
Brother MFC 7420... | Answered on Feb 22, 2017
I called Brother technical support and they walked me through the configuration and device settings. Can do it fine now.
Thanks, Carole
Brother MFC 7420... | Answered on Dec 22, 2016
amar printare soley jerox hocche?
Brother MFC 7420... | Answered on Oct 05, 2016
Press the Stop Button to cancel whatever you are doing on it. Then press Copy to be able to copy.
If you are printing to it from a computer it should just automatically get to printing when it is sent information.
Brother MFC 7420... | Answered on May 08, 2016
There are free OCR programs on the Internet. Here are a few WEB sites -
http://www.freeocr.net/
http://www.makeuseof.com/tag/top-5-free-ocr-software-tools-to-convert-your-images-into-text-nb/
http://www.bitwisemag.com/2/Free-OCR-Program
http://www.simpleocr.com/
Brother MFC 7420... | Answered on Dec 05, 2015
OCR program, a program that reconises what characters you have scanned from a original... I do beleive that the brother software package that comes with these printers has one included, go to brother web site and download full driver and software package for your machine
The ocr program that comes with your machine is called
ControlCenter2.0
link to brother site download US
http://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/monolasermfc/mfc7420_all.html?reg=us&c=us&lang=en&prod=mfc7420_all
Hi, follow the link below, it will show you where to buy just follow the instructions. I dont think this model is ion their current line up though. There is a similar one, MFC- 7450
http://www.brother.com.ph/Support/Where2Buy.aspx?locid=66&branch=Limketkai+Mall&
Brother MFC 7420... | Answered on Nov 26, 2015
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
Brother MFC 7420... | Answered on Nov 24, 2015
A9 is Brother's code "Abnormal scanning reference voltage"; try restarting the fax machine and trying again, or replace the scanner unit. (per Brother's website)
Brother MFC 7420... | Answered on Nov 11, 2015
The Brother printers have a counter which will shut the printer down when the preset number of copies has been reached. You can reset the counter and it should print again. I did this 4 months ago. It bought me a little time, but my printer has begun to print a solid line down the left side of each page. I have cleaned everything that I can access to rule out smudged glass, etc. Perhaps it is just best to replace the drum or buy a new printer(much to Brother's delight and design).
Brother MFC 7420... | Answered on Oct 08, 2015
Brother MFC 7420 All-In-One Laser Printer Logo
844 questions posted
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
View Most Popular
MFC Brother
  • MFC Brother
Most Popular Question
brother mfc 7420 light black lines
  • Office Equipment & Supplies
