20 Most Recent Brother CS-100-T Computerized Sewing Machine Questions & Answers
4answers
Presser foot down, but still get error "E1"
I had the same problem. It started after I took the cover off to fix something else. After I screwed the cover back on, I kept getting the E1 message even when the foot was already down. I took the cover off again, and I found that there is a metal tab at the top left of the front cover, that is pushed by a metal tab in the back that moves when you put the presser foot up or down. You can see this metal tab moving in the back if you put the foot up and down with the cover off. Just putting the foot down(I think) before putting the cover back on fixed it so one metal tab is on the correct side of the other metal tab.
9/1/2022 5:29:52 AM • Brother CS-100-T... • Answered on Sep 01, 2022
2answers
How can I fix upper thread tension problems?
I think that you are putting the bobbin in wrong, make sure that it is feeding thread the right way, look at your manual and see if this is the problem.
1/31/2018 3:25:15 PM • Brother CS-100-T... • Answered on Jan 31, 2018
2answers
Top stitches too tight - Brother CS-100
It's your bobbin tension not the top.
10/5/2017 4:26:33 PM • Brother CS-100-T... • Answered on Oct 05, 2017
2answers
Computerized brother cs 100 keeps untreading itself while sewing
it is not threading properly indicates that the needle /hook timing is off a bit or the bobbin thread tension is too tight
9/25/2017 5:38:42 PM • Brother CS-100-T... • Answered on Sep 25, 2017
2answers
I have a different model with the same problem. It started after I took the cover off to fix something else. After I screwed the cover back on, I kept getting the E1 message even when the foot was already down. I took the cover off again, and I found that there is a metal tab at the top left of the front cover, that is pushed by a metal tab in the back that moves when you put the presser foot up or down. You can see this metal tab moving in the back if you put the foot up and down with the cover off. Just putting the foot down(I think) before putting the cover back on fixed it so one metal tab is on the correct side of the other metal tab.
8/5/2016 5:28:50 AM • Brother CS-100-T... • Answered on Aug 05, 2016
Bobbin will not wind
For ~$25 you can purchase a stand-alone bobbin winder from the local fabric store (JoAnn's, Hancocks) or the internet, ie Amazon.com. ...
11/15/2015 4:49:16 AM • Brother CS-100-T... • Answered on Nov 15, 2015
2answers
I need a power cord and foot pedal for a Euro-pro
is this it?
http://cgi.ebay.com/Elna-Euro-Pro-Foot-Control-Pedal-Sewing-Machine-Serger-/200351821107?pt=LH_DefaultDomain_0&hash=item2ea5e62d33
2/13/2015 2:36:59 PM • Brother CS-100-T... • Answered on Feb 13, 2015
How to replace the bobbin winder in a CS-100
contact the mfg.
1/19/2015 8:00:04 PM • Brother CS-100-T... • Answered on Jan 19, 2015
When I try to wind bobbin and slide the shaft to the right, the motor whines but will not turn bobbin
You may need a new bobbin tire. It goes on the winder under the lid.
10/21/2014 8:48:41 PM • Brother CS-100-T... • Answered on Oct 21, 2014
2answers
My machine starting moving backwards.
I had this same problem. Something is wrong with the mechanism that moves the feed dogs. There's a slide switch on the back of the machine that raises and lowers the dogs. Unfortunately, most of the mechanism is made of plastic, so there may be a 'stripping' issue -- something's not catching correctly. I took off the throat plate and cleaned everything out (lots of lint in there!). Remove the bobbin, thread and needle. This way you can run the machine and see how things are moving inside. Notice the long screw/rod hanging in the back. This is supposed to rest in an indentation on an arm just below it. Mine had somehow worked its way out of that 'cup', so the dogs weren't moving correctly. Once I got that piece back in place, everything worked fine. Good luck!
10/19/2013 5:51:51 PM • Brother CS-100-T... • Answered on Oct 19, 2013
3answers
Brother Sewing Machine CS-100
actually e2 is the button hole lever being down. e6 means that the thread is tangled and to prevent the motor from overheating the machine automatically stops. All you have to do is re-thread the machine and take the bobbin out, untangle it and put it back in and sew. This usually works. If it keeps happening, there could be a few things wrong.
1. if you are using thick fabric your tension should be lower. normal tension is 5.
2. your machine is out of alignment. take it in to a service center, they can fix it in 5 minutes. to find a service center near you go to http://www.brother-usa.com/service/
3. your needle is old or bent and should be replaced.
4. Your needle is too thick, standard is 80. The thicker the fabric, the thicker the needle.
5/14/2013 9:00:26 PM • Brother CS-100-T... • Answered on May 14, 2013
Part for bobbin winder cs-100
http://www.sewingpartsonline.com/ has the part you need. It's called a bobbin winder "tire"
8/10/2012 2:08:09 AM • Brother CS-100-T... • Answered on Aug 10, 2012
Brother CS-100-T Computerized Sewing Machine Logo
101 questions posted
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Brother Sewing Machines
Most Popular Question
part bobbin winder cs 100
  • Sewing Machines
