20 Most Recent Big Button TV Universal Remote Questions & Answers
The Maplins big remote was made by Nikkai and doesn't have a code search button, or any other. The pairing is from pressing a sequence of buttons for a set amount of time, but lost the instructions so can't help further, sorry.
Big Button TV... | Answered on Feb 04, 2019
Even though your TV s remote control emits infrared light, it might have not sufficiant frequency as it supposed to be. The fault with its resonator crystal inside the circuit board need replacement. It will look like this. Replace it with exact frequency marked on it.8_16_2012_4_53_50_pm.jpg
Big Button TV... | Answered on Jan 12, 2019
This is what the manual says: Prgoramming the remote using PowerScan: 1. Manually turn OFF the device you wish to program (TV, VCR, DVD) 2. Press and hold the apprpriate device key (TV, VCR, DVD) until the red LED illuminates. This indicates that the Remote is in Programming mode. 3. Press and release the power key. The LED flashes once and stays ON, indicating that the remote is in PowerScan mode. 4. Press either the CH+ or CH- key Button repeatedly until the device switches ON. The CH+ Button searches upward in the code list, while the CH- key searches downward. (So since I have a Toshiba tv, I elected to search upward to get to 'T' faster. 5. When the device turns on, press and release the OK Button to store the new code and exit. To exit without setting the code, press the GO BACK Button. NOTE: If you press CH+ or CH- again after the device turns on, the device will not be programmed; you will need to repeat Steps 1-5 again. 6. Press and other operable key (VOL+/VOL-). If the device responds, no further programming is required. If not, repeat Steps 1-5.
Big Button TV... | Answered on Nov 11, 2018
Hi there i also had this problem with my "onn" television and there isnt an "onn" make - apparantly it is the same as pacific or schneider so if you get a remote from asda theyre really cheap less than a tenner - i found that look up either schneider or pacific and the first code it says should work for your tv!hope this helps!
Big Button TV... | Answered on May 29, 2018
These are the codes for Sharp TV; 0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122 Visit the site named 'Electro-help' for more details. Check this link and select the site. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Setup proceedings are described there in detail. Check this link too.
Big Button TV... | Answered on Oct 06, 2017
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Big Button TV... | Answered on Apr 11, 2017
These are the setup codes for Orion VCR.
0256 0310
Big Button TV... | Answered on Aug 20, 2016
I'm not showing that we have a code for the Magnavox/DVD combo. I have provided the power scan instructions. Please let me know if you have already performed these steps. Thanks.
This is to program your DISH remote to your TV:PowerScan1.Turn the TV on2.Press and hold the TV POWER button for three seconds - The LED shouldflash3.Press the TV POWER button 4. Press the UP orDOWN arrow buttons on the remote (about one press per second). Stopas soon as the device turns off. -The TV should turn off5.Press # - Now addressed
Big Button TV... | Answered on Aug 18, 2016
Tv code for a mitsubishi
Big Button TV... | Answered on Mar 13, 2016
The Tevion ARC 2030 (Sold at Aldi) is the same as the Radio Shack 15-310. Took me a bit to find it. Cut and paste this link into your browser for the manual: http://data.manualslib.com/pdf3/68/6702/670162-radio_shack/15310.pdf?9eafcf5e4d4c0046c669d595596d16fe&take=binary
Big Button TV... | Answered on Jan 19, 2015
Hello
Try these codes:
0181 0004 0005 0009 0003 0010 0095 0141
one of these should work 10878, 11217, 11360, 11599
ref:http://media2.comcast.net/anon.comcastonline2/support/help/faqs/remotes/DTAmanual.pdf
Big Button TV... | Answered on Dec 07, 2014
Please try these:10000, 10451, 10885, 10889, 10890, 11282, 11577
Big Button TV... | Answered on Jun 06, 2014
Big Button TV Universal Remote Logo
321 questions posted
Top Big Button Televison & Video Experts
ray gallant
Are you a Big Button Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Big Button Televison & Video
Most Popular Question
code sanyo r115 tv
  • Televison & Video
