20 Most Recent
As Seen On TV Swivel Sweeper Vacuum Questions & Answers
Swivel sweeper brushes slow with full charge even after cleaning brushes
When you say you cleaned out brush's are you talking about the build up between the bristles? I've found that I have to take the roller completely off and use fine needle nose tweezers to actually get all the stray hairs and caked on dirt as it hides close to the inside of the brush rollers. It's a bit more work to do this but I think you might benefit from this extra step!
Good Luck!!!
My swivel sweeper handle snapped right off where
You would need to check with the company where it was purchased. Some merchants just 'even-exchange' if you bought from a local retailer. Depends also on model/price. If it is lower-end item to begin with, may not be worth your trouble.
I bought a new battery charged it, and it starts
Possible that the drain of the mottor is exceeding the current requirement of the battery.
So check the battery for voltage and current according to the standard set, then check the vacuum motor to work from another source to determine the currrent factor to confirm if there is a mismatch or poor efficiency.
